SolaraGuy.com • View topic - Alpine Type R, 4 ohm or 2 ohm....
Postby Mossy » Sat Feb 07, 2004 12:51 pm
I bought a subwoofer and Q-loqic box from a local car audio shop, over a year ago, I did not write down if it was a four ohm or two ohm sub. Now I want to amplify it, and I cant fiqure it out.
Alpine Type-R SWR-1221D 12" Dual 2-ohm Component Subwoofer
or
Alpine Type-R SWR-1241D 12" Dual 4-ohm Component Subwoofer
It has the two terminal posts, that run to one side of the sub, then it has another wire that runs to the other side of the sub.
I opened the port hole up to do this investigating. I could not think of any other way to fiqure out the Ohms.. I hope you can help me here.
[Silverstars|Nokya Yellow Fogs|Black Clear Corners|Pioneer DEH-P7700MP|Kicker 15" CompVR|Hifonics Amp|Knuconceptz]
Mossy
Postby MGLax13 » Sat Feb 07, 2004 6:22 pm
Look carefully around the sub for any type of markings. I'm sure that somewhere, there has to be some type of indication. www.caraudioforum.com has alot of audiophiles that might be able to help you out. Also, you should call Alpine perhaps they can tell you how to look,
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby prophesized » Sat Feb 07, 2004 8:41 pm
use a multimeter to measure the resistance of the voice coils
prophesized
