SolaraGuy.com • View topic - RCA level output adapter for stock head unit
Postby nkx1 » Tue Mar 16, 2004 10:09 am
I was wondering if anyone can tell me where to find something like this. I don't want an adapter that converts speaker level to RCA, but rather an adapter that can obtain an RCA level output directly from the headunit. I know such an item exists for the '00 - '03 Acura CL, but I need one for Toyota ('99 Solara).
Thanks for any info you guys/girls have!
2001 SLE, Diamond White Pearl
nkx1
Postby ZXLNT » Wed Mar 17, 2004 2:36 am
Almost sounds like radio specific item. What radio does the Acura have?
ZXLNT
Postby indiglosolara » Wed Mar 17, 2004 9:01 am
Im not sure we have one for the Toyota Units for rca out. I do know there is a AUX input to have RCAs as a input.
I would use google and search... it does wonders...
this is what i found...
http://www.installer.com/acc/toyaux.html
and this site has what is available for toyotas
http://www.installer.com/cars/toyota.html
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Mudd » Thu Mar 18, 2004 7:38 am
About all you can do is get a line-level (or line-output) converter. It hooks into your stock speaker leads, and has an RCA output, usually with some kind of gain control built in. Then you have to go find a switched (accy) power source in your vehicle to turn your amp on with the car.
Mudd
Postby indiglosolara » Thu Mar 18, 2004 9:03 am
Mudd wrote:About all you can do is get a line-level (or line-output) converter. It hooks into your stock speaker leads, and has an RCA output, usually with some kind of gain control built in. Then you have to go find a switched (accy) power source in your vehicle to turn your amp on with the car.
:werd:
thats about all i can think about. I have installed them into a couple of my friends cars and they dont work bad. They have gain controls and level outputs.. so you can control the sound..
Best buy has it for like $15 bucks or you can look for ones online for cheaper...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby SolaraFun » Wed Mar 24, 2004 11:47 pm
I bought mine at Best Buy for $20/I must have missed the sale. :D
Here's what it looks like
I'm also adding an amp and subs to my stock deck. I want to splice the rear speaker wires from directly behind the deck. Where can I find a wire diagram that will tell me which wires are the rear ones? (I'm wondering if they will be the red/black that I can see on the rears, but I won't be pulling the deck again until this weekend)
~KT~
2002 Solara SE V6
+ 2 12" Sony Xplod Subs w/800w Amp
- Reverse Indiglo gauges
+ Carbon Fiber bezel & ebrake cover
"+" mesh grill
SolaraFun
Postby HKSV6SLE » Fri Mar 26, 2004 1:05 am
i got one of those hahah
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby SolaraFun » Fri Mar 26, 2004 8:41 am
HKSV6SLE wrote:i got one of those hahah
Great! Do you remember the colors behind the deck are the right and left rear?
~KT~
2002 Solara SE V6
"+" mesh grill
SolaraFun
Postby B_Master_Flash » Fri Mar 26, 2004 3:29 pm
the wires behind the deck are marked, you should have no problems
B_Master_Flash
Postby SolaraFun » Sat Mar 27, 2004 7:50 pm
What do you mean by marked because they only have little dashes of paint on them, no words? Hey HKSV6SLE, there's 4 wires from the inline converter: 2white (negs) and 2gray (positives) = which wires from behind the deck did you splice these into? Or if there is anyone that has a diagram or Haynes/Chilton Manual that can look up the rear speaker Right (pos/neg) and Left (pos/neg) color of wire that is behind the radio deck. Any help is greatly appriciated.
~KT~
2002 Solara SE V6
"+" mesh grill
SolaraFun
Postby Mudd » Thu Apr 01, 2004 8:30 am
Just tap them off the rear speakers. The amp's most likely going in the trunk anyway. Then all you have to do is get switched power and a power line from the battery and run it back to the amp. You can get a harness and then a reverse harness from Best Buy, wire them together, and catch switched power there without having to cut anything behind the deck (and henseforth voiding you warranty). It'll cost like $35 but it's worth it, and makes life MUCH easier.
BTW - the switched power is the red wire on that aftermarket harness. It can be found all kinds of different places, but that's the easiest way for the masses.
Mudd
Postby MalBandito99 » Fri Apr 09, 2004 8:33 am
Dont be cheap. IF you got the means to, buy a new h/u with AUX output on it and do it right. You'll get so much better sound quality, no hissing, and better range of amplification.
MalBandito99
