New speakers all around... first post
- oompah2788
- Regular SolaraGuy Member
oompah2788 wrote:thanks for the replies. I dont really mind drilling new holes, I just dont want to cut the panels or make the holes bigger. As long as the size is the same i probably can manage a way to mount them. To wire new speakers do i just need to resolder them to the stock wires or they have some sort of twerminal or connector?? Am i going to ned new wiring??Where would the amp go for connection and where could i put it? THANKS AGAIN!
Jon11582 wrote:I tried to replaced my stock base toyota speakers with the stock Solara JBL speakers from someone with the same car who upgraded thier JBLs to something else. Even these didnt bolt in.
The rear 6x9s dropped in fine, no redrilling, but the front needed to be redrilled to put the stock JBLs in. I never ended up doing the fronts hough...I also had to resolder the rear since the terminals didnt match either (the seller may have cut above the harness so Im not sure about that).
You figured replacing stock with stock would fit in with no modification but that wasnt the case either, so I think you'd be very hard pressed to find speakers thatll fit in without modification.
B_Master_Flash wrote:Odd, my CDT CL-61s fit in the slot where my stock JBLs were w/o any problems..
pro956 wrote:B_Master_Flash wrote:Odd, my CDT CL-61s fit in the slot where my stock JBLs were w/o any problems..
just wondering, what amp do you have powering the cl-61s
and how do they sound?
those are the same separates i'm going to be using-- till i move to kickpanels
w/the image enhancement kit...
thanks
oompah2788 wrote:Will running an amp improve SQ or does it just let you play them louder??? Could i just have components up front and some focal 6x9's running of the HU??? If i get new 6x9's does it have to have the tweeter built in the middle of the midbass or do i look for the one with no tweeter??? And also, what does a crossover do? Does it filter the higher signal or something to the midbasses and filter the lower signals to the tweeters?? sorry if that doesnt make sense. just trying to learn.My fav. artisests are probably the living legends! so good. g&E (grouch and eligh)
