SolaraGuy.com • View topic - Amp and sub install
Amp and sub install
Amp and sub install
Postby oompah2788 » Sun Apr 18, 2004 4:38 pm
Is installing an amp and sub in the trunk easy saying i have a HU with rca outputs and and box for sub. I just need to know how i would go bout wiring it. I looked in the DIY section but found nothing. Someone should post this since it seems pretty simple. Thanks!
oompah2788
Postby geminimouse » Sun Apr 18, 2004 9:19 pm
It is simple...
battery-fuse-amp
ground - amp ground
hu rca - amp rca
remote - amp
No offense, but it sounds like u shouldn't be doing the wiring urself. You gotta get help from someone who knows how to do it. Electrical stuff is dangerous :wink:
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby oompah2788 » Mon Apr 19, 2004 8:17 pm
:evil: :evilbat: ahhh what is ground? like solder a wire to the chassis or something? and what do you mean remote to amp?? come on, someones gotta learn sometime riight??? :vamp: :changes: :shocked!: :bad-words: :wink:
oompah2788
Postby oompah2788 » Mon Apr 19, 2004 8:21 pm
please please someone make a DIY on this. IT SEEMS SO EASY!!!! :D
solaraguy should make a section just on articles, like team integra. No offense but that forum has a good article section. check it out. NO OFFENSE NOW! :bday:
oompah2788
Postby Jackass-Jeff » Mon Apr 19, 2004 8:24 pm
link it :D
1GR-FE ftw!
Jackass-Jeff
Postby Mudd » Sun Apr 25, 2004 9:25 pm
I agree with Geminimouse. It SEEMS easy, but it's more than just hooking up 5 wires and cranking the bass. There's all KINDS of things you should know, wire placement and configuration, fusing, ground loops, and stuff like that. Not to say anything of the actual logistics in runnning wires in cars (and Solaras are some of the bigger pain in the rears to run wires through). Then there's the tuning of the system (the single most important part of the install, and the part no one can seem to get right).
It'll cost you like $60 at Best Buy to have it installed, you'll get a lifetime warranty, it'll take them 2 hours to your 2 days, and if something goes wrong, you take it to them to deal with. Do that for now, and start small with other things, like maybe speakers or something.
Mudd
Postby B_Master_Flash » Mon Apr 26, 2004 4:13 pm
Mudd wrote:It'll cost you like $60 at Best Buy to have it installed, you'll get a lifetime warranty, it'll take them 2 hours to your 2 days, and if something goes wrong, you take it to them to deal with. Do that for now, and start small with other things, like maybe speakers or something.
Best buy makes you buy their outrageously overpriced Fosgate wire kits, I would recommend buying an amp kit from Wallmart, then bringing it to a local stereo shop for installation (prolly around $80)
B_Master_Flash
Postby nYsOlaRaKiD » Mon Apr 26, 2004 5:39 pm
I agree with the guys. Ur better off having a shop do it. I had my subs and amp installed this past weekend by a shop, and it wasnt the easiest thing in the world form what i was observing. Pulling a wire from the trunk to the battery taking off a few pieces of paneling.... and some other stuff. You dont wanna mes anything up and then regret having started the installation all together.
99 SE V6 5spd 20% tints and bone stock
SOLD: 2000 SE V6 A/T Black on Black 20% tints clear corners, 04 17" solara rims, JL audio 2 10" W7s with Kenwood amp
nYsOlaRaKiD
Postby Duffman » Fri Aug 27, 2004 8:59 am
You can also check Crutchfield.com for guides - they have detailed guides for "do it yourself"ers.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby gogeta » Sun Aug 29, 2004 9:47 am
never ever ever go to best buy....they r the biggest hackers on the planet tore this girl i knows dash apart to put in her head unit....her heat and ac never worked again.....not to mention they broke the seal on my box by mounting my amp to it.....tried tellin me the box was fine so i turned on the system and wouldn't u no.....air is comin out of the screw holes.....inspired me to learn how to do it on my own.....once i did never looked back.....wow....long huh....
arctic frost pearl/gray 04 se
trd exhaust/air filter
mb quart 2 way 6x9s front
eclipse 4-way 6x9s rear
kicker kx 600.1/kicker l7 dual 2ohm
alpine head unit itching to be put in...
gogeta
Postby SleeperSolara » Fri Nov 05, 2004 9:56 am
oompah2788 wrote::evil: :evilbat: ahhh what is ground? like solder a wire to the chassis or something? and what do you mean remote to amp?? come on, someones gotta learn sometime riight???
Nope newbie you never solder the ground wire to the chassis that plain stupid. :o :o :o :o
Remote to amp means to turn up the gain, and also to turn on the amp.
Postby Ford_Fixorrepairdaily » Sat Nov 06, 2004 4:35 pm
installing a system is easy, but not recommended for virgins. i say bring it to the shop
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby swimshady906 » Sun Nov 07, 2004 11:58 am
deleted
02' S2000 Silverstone
swimshady906
Postby geminimouse » Sun Nov 07, 2004 12:48 pm
swimshady906 wrote:Im going to make a fully detailed post today on how to install a headunit , after market components, seperate amps for your speakers, and subs today with looots of pictures :D
koo....now could people stop replying to this old thread...
08 Accord Coupe
geminimouse
