SolaraGuy.com • View topic - where are my stock stereo harness?
Postby megatronv7 » Mon Apr 26, 2004 7:48 pm
Can't seem to located my 1 of 2 harness plug for my oem cd player?
Does anybody have a diagram of where they are?
megatronv7
Postby geminimouse » Mon Apr 26, 2004 7:55 pm
it'll be better if u put info about ur solara.
year?
jbl or non jbl?
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby nkx1 » Mon Apr 26, 2004 8:03 pm
If you have a '99 with JBL, there may only be one. I have a '99 w/JBL, and there was only one. The amp is built into the JBL headunit, unlike the other years.
2001 SLE, Diamond White Pearl
nkx1
Postby megatronv7 » Mon Apr 26, 2004 10:04 pm
i have a 2000 solara. it came with jbl cd player with cassette. It has oem amplifier behind the glove compartment.
megatronv7
Postby MGLax13 » Mon Apr 26, 2004 10:33 pm
If you look in the hole that the radio goes into, to the right, there are two plugs. Those are the two that you would find on the stock stereo, unplug them and then plug the normal Toyota harness that you would find in any stereo store into that, it automatically bypasses the amp. If you want to be thorough, take out the glove box and remove the amp all together, takes about a half hour.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby megatronv7 » Wed Apr 28, 2004 3:02 pm
There's only one. I plugged it in and still doesn't work. Can somebody snap a picture of their stock harness?
megatronv7
Postby geminimouse » Wed Apr 28, 2004 3:54 pm
megatronv7 wrote:There's only one. I plugged it in and still doesn't work. Can somebody snap a picture of their stock harness?
Don't feel like takin it apart...
ASCII drawing :P
They should be right next to each other. In the space where the headunit was, around where the 1 and 2 are in the picture. They are not connected to the stock head unit.
________________
|! ! ! ! ! ! !| 1 | 2 | !|
08 Accord Coupe
geminimouse
Postby megatronv7 » Thu Apr 29, 2004 3:42 pm
Guy at circuit city says there's only 1 set of plugs that go in the cd player.
Is he right? I have an oem jbl external amplifier.
In the jbl cd player, is the other plug for a cd changer?
megatronv7
Postby geminimouse » Thu Apr 29, 2004 4:19 pm
There's only one harness coming from the amp that connects to the head unit.
08 Accord Coupe
geminimouse
Postby megatronv7 » Thu Apr 29, 2004 4:23 pm
The other plug in the jbl cd player is left open correct?
megatronv7
Postby geminimouse » Thu Apr 29, 2004 4:37 pm
Does ur oem head unit look like this?
08 Accord Coupe
geminimouse
Postby B_Master_Flash » Thu Apr 29, 2004 8:16 pm
Ok, on the JBL system there is a plug that goes into the back of the stock JBL HU, it goes to an amp, from the amp it goes back to behind the deck into the stock wiring plugs, there are two of them. They were never plugged into the HU, so you might have to dig for them. If you really can't find them, follow their path from the amp.
B_Master_Flash
Users browsing this forum: Google [Bot] and 9 guests
