SolaraGuy.com • View topic - how to remove stock 6x9"
Postby ZapmanSQ » Fri May 07, 2004 1:49 pm
i'm going to install my PG octaneR 6x9" replace my stock 6x9", but i see something that can't be done without instruction. so if you have any experienced how to remove it please post it out! thanks
ZapmanSQ
Postby geminimouse » Fri May 07, 2004 2:13 pm
I scanned the crutchfield instructions and sent it to a couple people....forgot who tho :-?
Hope they see this and pass the info on 8)
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Jon11582 » Fri May 07, 2004 2:32 pm
Its a real pain in the rear. No modification necessary, but your need to take out the rear shelf, which means you need to take out both quarter panels, and even the front seatbelt. In a coupe, its not a walk in the park.
Those crutchfield instructions was what I used.
2000 Black Solara SE
Jon11582
Postby prophesized » Fri May 07, 2004 9:00 pm
tear off your shirt, scream like the hulk, then rip out the 6x9's with your bare hands. that always works for me.
prophesized
Postby MalBandito99 » Sun May 09, 2004 4:43 pm
Actually I used some gardening scissors which I thought were for metal cutting, and wore them down to bare metal cutting each brace for the 6x9s. Took me 1 1/2 hours and i got them out. Damn things were blown anyways from being played too loud thru my aftermarket h/u.
MalBandito99
Postby speedgraphix » Sun May 09, 2004 6:36 pm
ok.. youll need to take off the carseat mounting brackets on the rear deck. youll also need to remove the handle behind the seats on both sides. Heres some picsImageImageImageImageImage then you should be able to just slide the rear deck out, and have access to the speakers. good luck
2001 Black SE V6
speedgraphix
Postby ZapmanSQ » Sun May 09, 2004 6:41 pm
thanks, looks like i need some times to find out the easy way to do it. by the way the 6x9 stock has only 3 screws behind the metal and the aftermaket speakers has 4 screws in it, so do i need to drill the hole or not? thanks for your info
ZapmanSQ
Postby speedgraphix » Sun May 09, 2004 7:31 pm
when my bf and i put the infinitys in.. we just took the stock speakers out of the basket and RTV'd the new speakers in, then used the stock basket with the new speakers. just be warned, depending on your stock radio and sound system ( i had the jbl "upgrade") you will ruin the stock speakers if you take it out of the basket. also you will need to RTV or seal on the underside too. or.. you can drill directly into the deck
2001 Black SE V6
speedgraphix
Postby ZapmanSQ » Sun May 09, 2004 7:40 pm
thanks a lot for your help, hopefuly i can done without any troubles.
ZapmanSQ
Postby ZapmanSQ » Thu May 13, 2004 12:39 pm
speedgraphix wrote:when my bf and i put the infinitys in.. we just took the stock speakers out of the basket and RTV'd the new speakers in, then used the stock basket with the new speakers. just be warned, depending on your stock radio and sound system ( i had the jbl "upgrade") you will ruin the stock speakers if you take it out of the basket. also you will need to RTV or seal on the underside too. or.. you can drill directly into the deck
hey speedgraphix!
i just installed the speakers today. hoo.... if i don't have your info i must be messing a lot things, anyways everything go smooth now. i have to drill the hole due the speakers side hole difference then stock. it's took me like 4 hours to complete everything. thanks a lot and i appreciated for your help. thanks speedgraphix!
ZapmanSQ
Postby ZapmanSQ » Mon May 17, 2004 3:01 pm
its all done :D
ZapmanSQ
Postby redkysolarase » Mon May 17, 2004 6:26 pm
Do you really have to remove all that shiznit just to get those little speakers out? If so I believe I'll just leave them there and get my new ones installed somewhere else...
redkysolarase
Postby ZapmanSQ » Mon May 17, 2004 6:55 pm
you can do it yourself, you'll see a lot fun. but yeah you need to remove like he's told or you gone pay big cash for just only the rear speakers not even front yet!
ZapmanSQ
Postby NVDIS1 » Wed Jun 02, 2004 11:09 am
when i put new 6x9's in i also installed dynamat extreme over everything i could! did not wanna take all that shoot out again :evil:
http://members.cardomain.com/rgztoy
