SolaraGuy.com • View topic - Alpine Type R 6.5' in rear deck?
Postby neo6205 » Sun May 23, 2004 2:10 pm
I have 6.5' Alpine Type R coaxials I am putting in the rear deck 6x9' location. I know these have a high sitting tweeter so I was wondering if anyone has put these in a 99 Solara SLE? Also, if they had to refab the speaker grills to fit them. Thanks!
neo6205
Postby Jackass-Jeff » Mon May 24, 2004 7:50 am
Coaxials should be fine UNLESS the tweeter sticks out ridiculously... if it sticks out up to about 1/2 inch I think it'd be ok.
1GR-FE ftw!
Jackass-Jeff
Postby WortownSolara » Mon May 24, 2004 8:27 am
Type R's should not hit the cover. I do suggest when making the baffle though, bottom mount it, and cut out the hole to fit the surround. this will give you an extra 1/4" to a half 1/2" depending on what size abs plastic or MDF is used. excellent choice in speaker by the way, great tonal ballance for a rear
If it doesn't kill you.....it only makes you faster!
WortownSolara
Audio Guru
Audio Guru
