SolaraGuy.com • View topic - Air space for Eclipses?
Postby kronos98 » Wed Jun 16, 2004 10:48 pm
I have 2 12" DVC Aluminum Eclipses (SW8122DVC). The specs say Vas = 3.2 cu ft. I'm assuming that means "vented air space?"
But also, in the information for the speaker on the Eclipse website, it says the subs are for "Small Sealed-Box Enclosure " ??
Does anyone know how much airspace I need for these speakers?
kronos98
Postby ZXLNT » Thu Jun 17, 2004 7:26 am
The VAS is the equivalent amount of air space that has the same compliance as the speakers suspension. Does the eclipse sight not give any box specs????
Hmm I guess not. Try a program called WINSD its a subwoofer box design program... Or get on sounddomain.com in the subwoofer forum and ask. Seems like the Eclipse subs are fairly popular...
ZXLNT
Postby kronos98 » Fri Jun 18, 2004 10:32 pm
so VAS means "volume of air equal to the mass of the speaker"
if the specs say VAS: 3.2 cu ft.......I need 3.2 cu ft per sub?? that's insane!
kronos98
Postby Jackass-Jeff » Fri Jun 18, 2004 10:52 pm
kronos98 wrote:so VAS means "volume of air equal to the mass of the speaker"
yup. =P You're gonna love how they sound 8) It's gonna be a pretty damn big box... my friend has 2 Aluminum DVC 12s and the box fills a good chunk of his crappy ass trunk =P (chevy mailbu... 01) lol
1GR-FE ftw!
Jackass-Jeff
Postby i20solara02i » Sat Jun 19, 2004 1:38 am
yup. =P You're gonna love how they sound 8) It's gonna be a pretty damn big box... my friend has 2 Aluminum DVC 12s and the box fills a good chunk of his crappy butt trunk =P (chevy mailbu... 01) lol
haha ya which those sub where mines :evilbat: but then move on to something bigger :drinking:
i20solara02i
Postby ZXLNT » Sat Jun 19, 2004 2:47 am
No thats not how it works. Let me see if I can find my loudspeaker design cookbook I have laying around. You have to figure in many factors. All the Thielle Small Parameter. I am guessing around 1.5 cubic feet or so. It depends on low you want the box tuned.. Give me a bit and I'll come up with something for you...
ZXLNT
Postby Jackass-Jeff » Sat Jun 19, 2004 6:46 am
i forgot to mention, he's running a ported box. not sealed...
1GR-FE ftw!
Jackass-Jeff
Postby pro956 » Sat Jun 19, 2004 8:00 am
"Vas Volume of air equal to the driver compliance.
This can be thought of as how stiff the movement of the cone is. The value is given in litres or cu inches. There are a lot of variables that determine the Vas, so you can’t really say that high values of Vas mean a certain thing or are better. A single or double suspension spider will affect Vas, so does the size of the cone. The temperature of the air and also the humidity will affect Vas and so it is one of the hardest parameters to evaluate.
vas give suspension compliance not the perfect enclosure.
go with about 3.5cubes after displacement for the whole box (not each sub)
31.17 hz 4" port diameter
6" length
call up ecplise and double check
their number should be somewhere on their site
AIM: pro956
2002 5-speed se v6
pro956
Postby kronos98 » Sat Jun 19, 2004 9:20 am
dang. i'm still lost. so how big is the box supposed to be? haha
kronos98
Postby WortownSolara » Sat Jun 19, 2004 10:13 am
ok believe it or not, and im sure yall wont, but the aluminums and titaniums happen to be our best selling subs. we go for .88 cubic feet. If you go any larger without venting, there is quite the possibility of cone noise. But thee 88 still allows it to slam pretty low, and loud at that too.
If it doesn't kill you.....it only makes you faster!
WortownSolara
Audio Guru
Audio Guru
Postby Jackass-Jeff » Sat Jun 19, 2004 10:37 am
WortownSolara wrote:ok believe it or not, and im sure yall wont, but the aluminums and titaniums happen to be our best selling subs. we go for .88 cubic feet. If you go any larger without venting, there is quite the possibility of cone noise. But thee 88 still allows it to slam pretty low, and loud at that too.
expensive blood you guys have in mass. x_x rich area?
1GR-FE ftw!
Jackass-Jeff
Postby ZXLNT » Sat Jun 19, 2004 3:41 pm
kronos98 wrote:dang. i'm still lost. so how big is the box supposed to be? haha
3.5 total cubic feet, AFTER allowing for the amount of air displacement the speakers and the ports and ANY internal bracing takes up. So the actuall internal airspace will be BIGGER than 3.5 cubic feet but after you get the speakers and ports installed whats left should be 3.5 cubic feet...
ZXLNT
Postby kronos98 » Sat Jun 19, 2004 10:50 pm
so if i have 2 12" dvc aluminum eclipses...the total enclosure space is going to be larger than 6.4 cf for a sealed box? isn't that basically all the usable trunk space that we have???
kronos98
Postby ZXLNT » Sat Jun 19, 2004 11:41 pm
kronos98 wrote:so if i have 2 12" dvc aluminum eclipses...the total enclosure space is going to be larger than 6.4 cf for a sealed box? isn't that basically all the usable trunk space that we have???
3.5 cubic total for both subs, not each sub. That will fit in the trunk easily.. Again you will need to figure how much air each subwoofer displaces, the amount of air the port displaces and how much air any bracing will displace. After you have that figure then you have to determine how big the box needs to be to have an interior airspace of 3.5 cubic feet total. If you subs and ports and bracing use up .5 cubic feet then your box actually needs to be 4.00 cubic feet in airspace to allow for the subs, ports and bracing displacement...
ZXLNT
Postby pro956 » Sun Jun 20, 2004 10:29 am
heh, thought i was pretty clear
kronos understand now?
AIM: pro956
2002 5-speed se v6
pro956
