SolaraGuy.com • View topic - ohm stability
ohm stability
ohm stability
Postby Callen » Sat Jun 19, 2004 1:06 am
is it safe to run a 1.5 ohm operation on a 2 ohm stable amp? Does dual 6-ohm sound good on a 2 ohm amp?
2 JL 12w6's powered by
Hifonics BX1000D amp@ 1.5 ohms run off an
Alpine CDA-9833
soon to be
CDT EF61CFi/25 6.5" components.
Callen
Re: ohm stability
Postby pro956 » Sat Jun 19, 2004 7:34 am
Callen wrote:is it safe to run a 1.5 ohm operation on a 2 ohm stable amp? Does dual 6-ohm sound good on a 2 ohm amp?
is it safe? depends on the amp
audiobahn amp? no
also if you're askin if you can run 1.5ohms mono on a 2ohm stereo amp, t hen you'll definately break it-- even if it's much better than audiobahn
AIM: pro956
2002 5-speed se v6
pro956
Re: ohm stability
Postby Callen » Sat Jun 19, 2004 8:39 am
audiobahn amp? no
my question had nothing to do with audiobahn's integrity thankyou very much. Also, it's not a stereo amp, it's mono (english gets hard to read sometimes).
::God i love that amp::
Alpine CDA-9833
soon to be
Callen
Postby WortownSolara » Sat Jun 19, 2004 10:17 am
u must understand that impedance fluxes. Believe it or not but a 2 ohm load will more than definatly hit 1.5 ohms at certain peaks and valleys. Going to a 1.5 ohm load will more than definatly blow most amps on the market, with the exception of Zapco, xtant, and just a couple others.
If it doesn't kill you.....it only makes you faster!
WortownSolara
Audio Guru
Audio Guru
Postby Callen » Sat Jun 19, 2004 1:07 pm
ok thankyou both for your input.
anybody suggest a good 1 (or 1.5) ohm stable amp? I usually come across audiobahn and rockford fosgate but idk, web-sites don't usualy put out all items by a maker.
Alpine CDA-9833
soon to be
Callen
Postby indiglosolara » Sat Jun 19, 2004 1:11 pm
Callen wrote:ok thankyou both for your input.
jl audio... the 500/1 or 1000/1 is good for 1.5 ohm up to 8ohm.. and no matter what ohm you play at you get the same resposne..
great amps....
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Jackass-Jeff » Sat Jun 19, 2004 1:12 pm
great amps....
I think they are only great amps when matched to JL subs (from what I hear)
1GR-FE ftw!
Jackass-Jeff
Postby Callen » Sat Jun 19, 2004 2:43 pm
The audiobahn A2200HCT is 1600 watts RMS at 1 ohm. That would cover any woofers I want in the future, but the only extra thing that it has (that my current one doens't) is a variable bass boost frequency from 40-100 hz (instead of just 45).
I'm having trouble deciding between that, and the JL 500.1 (which has lots of controls, but not that much powwer [underated ?¿?])
Alpine CDA-9833
soon to be
Callen
Postby ZXLNT » Sat Jun 19, 2004 3:38 pm
For an inexpensive amp look at a JBL 1200.1. Fairly inexpensive and 1 ohm stable. Should handle 1.5 just fine.
ZXLNT
Postby pro956 » Sun Jun 20, 2004 10:25 am
great amps....
they're always great amps... hard to get a decent deal on them though
AIM: pro956
2002 5-speed se v6
pro956
Postby B_Master_Flash » Sun Jun 20, 2004 11:20 am
WortownSolara wrote:u must understand that impedance fluxes. Believe it or not but a 2 ohm load will more than definatly hit 1.5 ohms at certain peaks and valleys. Going to a 1.5 ohm load will more than definatly blow most amps on the market, with the exception of Zapco, xtant, and just a couple others.
Just about any class D amp will be able to handle down to 1 ohm, JBL 1200.1 or HiFonics BX1000D are cheap and good amps. The fact that the subs are Dual 6 ohm (audiobahn alum im guessing?) has no effect on the sound.
B_Master_Flash
Postby Callen » Mon Jun 21, 2004 12:11 am
JL 12W6's (old school). I'm gona sell my audiobahn A/B 400 rms to my friend for about $120 and try and get a JL 500.1 with some saved money +birthday funds (I might save for the JL 1000.1)
Alpine CDA-9833
soon to be
Callen
Postby WortownSolara » Mon Jun 21, 2004 6:36 am
not just any class D will handle one ohm, in fact most dont want too becuase of the increased distortion, not to mention you are BEATING on the power supply.
WortownSolara
Audio Guru
Audio Guru
Postby pro956 » Mon Jun 21, 2004 7:05 am
there are a bunch that don't...
AIM: pro956
2002 5-speed se v6
pro956
Postby Callen » Mon Jun 21, 2004 9:46 am
pretty much every 1 ohm stble amp i see is pushing atleast 850 watts for 1 ohm.. and i'd rather just save up for the jl 1000.1
Alpine CDA-9833
soon to be
Callen
