SolaraGuy.com • View topic - Plan on getting 2 alpine type R subs,but will this amp work?
Postby CashPlz00 » Mon Jun 28, 2004 6:20 am
This is the system I bought a few months ago: http://www.circuitcity.com/detail.jsp?c=1&b=g&u=c&catoid=-8871&qp=0315431551695&oid=83463&m=0
It sounds really good, but I want a pair of alpine type r's to really rock the neighborhood (litterally). However, since I already have an amp, will this amp be sufficent enough to run the type r's? If not, can you recommend me an amp?
Thanks guys
CashPlz00
Re: Plan on getting 2 alpine type R subs,but will this amp w
Postby pro956 » Mon Jun 28, 2004 9:32 am
CashPlz00 wrote:This is the system I bought a few months ago: http://www.circuitcity.com/detail.jsp?c=1&b=g&u=c&catoid=-8871&qp=0315431551695&oid=83463&m=0
Thanks guys
no way
try an amp from tru tech
better yet, let us know what your budget is and we'll tell you
i doubt u would want put down that much money for a tru tech amp unless u were getting higher end subs
AIM: pro956
2002 5-speed se v6
pro956
Postby B_Master_Flash » Tue Jun 29, 2004 10:04 am
You should consider either buying a new box or making one of your own, if you want loud you can't beat ported. Have you bought the Type Rs yet? They make them in Dual 2 and Dual 4 ohm, if you haven't bought them yet I would recommend getting the Dual 4s and wiring them to 1 ohm on a BX1000D.
B_Master_Flash
