SolaraGuy.com • View topic - Which amp???
Which amp???
Which amp???
Postby oompah2788 » Wed Jun 30, 2004 10:19 pm
I've decided to get the CDT Cl-61A components. Now I need an amp to push those speakers and a deck. I might just run the rear 6x9's off the h/u so i need a 2 channel amp. When running the rears off the h/u would i need to power it down some so the speakers wont blow? So which amp and h/u should i get? For the h/u it dont have to be too high tech i just want at least a 4 or 5 band eq and itll be good if it can also play mp3's but its not needed. Thanks ALot! :D
edit: The cdt's are 90 watt rms (4ohm)
oompah2788
Postby SoLaRa_PimPin99 » Thu Jul 01, 2004 8:08 am
An Alpine h/u is always a great way to go when building a system! :wink:
99 Solara SE V6 Black w/ Blue Pearl (New Paint job)
19" Niche F-16 (215-35-19 Nitto gen's)
Eibach Pro-kit
Tokico Blue Struts
Dual Cat-back Exhaust
Altezza Carbon Fiber tailights
SoLaRa_PimPin99
Postby geminimouse » Thu Jul 01, 2004 8:16 am
Do you have a price range? :P
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby oompah2788 » Thu Jul 01, 2004 5:10 pm
I would like to be able to get both for under $600.
oompah2788
Postby oompah2788 » Thu Jul 01, 2004 6:07 pm
How are the power acoustic amps? I found two amps from them at a very cheap price. The LT480/2 which is 100x2 @ 4ohms and is only $100, and the OV2-400 which is 85x2 @ 4 ohms and that ones only $94. Tell me how these are. Thanks.
oompah2788
Postby pro956 » Thu Jul 01, 2004 7:53 pm
oompah2788 wrote:How are the power acoustic amps? I found two amps from them at a very cheap price. The LT480/2 which is 100x2 @ 4ohms and is only $100, and the OV2-400 which is 85x2 @ 4 ohms and that ones only $94. Tell me how these are. Thanks.
they suck
AIM: pro956
2002 5-speed se v6
pro956
Postby whiteflash » Thu Jul 01, 2004 9:15 pm
Crunch is a good amp
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby oompah2788 » Fri Jul 02, 2004 1:34 am
they suck
soooo...... wanna reccomend an amp for me? :bday: :D
oompah2788
Postby Turbosolara » Fri Jul 02, 2004 1:36 am
I think your setting is very wierd. i would suggest run all speakers with amp just in case the sound have uneven loudness/clearness. i think soundstream have one 4 channel amp under $150. dont just look at power. power doesnt means anything, however, the brand reputation is the way will make serious different.
i have a rockford fosgate 200w 4 channel ( i think its only like 35w RMS per channel), it served me very well and i am very satisfy with it. just remeber there is a limit that you ear only can take.......
Postby oompah2788 » Fri Jul 02, 2004 2:07 am
yeah.. someone told me that the stock rear speakers may not be able to handle the power from an amp, so they told me it would be better to run the rears off the h/u instead. Would the music be best if the rears were removed completely or do the rears add to the music (for the front passengers that is)?? Or should i get some new 6x9's and get a four channel amp?? what to do what to do......Thanks alot
oompah2788
Postby Callen » Sat Jul 03, 2004 12:05 am
oompah2788 wrote:yeah.. someone told me that the stock rear speakers may not be able to handle the power from an amp, so they told me it would be better to run the rears off the h/u instead. Would the music be best if the rears were removed completely or do the rears add to the music (for the front passengers that is)?? Or should i get some new 6x9's and get a four channel amp?? what to do what to do......Thanks alot
6x9's will typically handle more power than components of same quality (and/or be able to handle more bass). Regardless,, an amplifire is an amplifire. A 4-channel amp from RF will be 100 times better than the amp that the alpine HU comes with (I turn the amp on my CD-player off). This is why you should just get a 4-channel instead of running off the head unit.
2 JL 12w6's powered by
Hifonics BX1000D amp@ 1.5 ohms run off an
Alpine CDA-9833
soon to be
CDT EF61CFi/25 6.5" components.
Callen
Postby oompah2788 » Sat Jul 03, 2004 12:55 pm
so i should just get a 4channel amp and run all the speakers off that? wouldnt 100wrms be too much for the stock rears??? :oops: :angel: :bday:
oompah2788
Postby pro956 » Sat Jul 03, 2004 1:16 pm
oompah2788 wrote:so i should just get a 4channel amp and run all the speakers off that? wouldnt 100wrms be too much for the stock rears??? :oops: :angel: :bday:
wayyyyyy too much, just remove the stock speakers
and get a nice 2-channel for the components (nice choice on those btw)
AIM: pro956
2002 5-speed se v6
pro956
Postby oompah2788 » Sat Jul 03, 2004 7:10 pm
if i remove the rears would sq be reduced? would it sound "off" like the rear sounds "empty"? or is it better to actually remove the speakers? could i just leave them in and not wire them? ORRR is there some good 6x9s that i can get that will complement the cdt's and dont cost too much?
Thanks
oompah2788
Postby pro956 » Sat Jul 03, 2004 8:21 pm
oompah2788 wrote:if i remove the rears would sq be reduced? would it sound "off" like the rear sounds "empty"? or is it better to actually remove the speakers? could i just leave them in and not wire them? ORRR is there some good 6x9s that i can get that will complement the cdt's and dont cost too much?
Thanks
sq will improve without them
u could just leave them in and not wire them, but if you have a sub system that u want to be as loud as possible, take them out
use the extra money on a better amp
you can do much better than crunch too...
tru tech, jl audio, arc audio, zapco, us amps, linear power, etc etc
AIM: pro956
2002 5-speed se v6
pro956
