SolaraGuy.com • View topic - Thinking about becoming a Solara Owner
Postby SleeperSolara » Wed Feb 22, 2006 8:07 am
leepoffaith wrote:Thanks for all your suggestions. I'll make sure to check all the interior items including the cup holders and cd player. As for the 90k maintenance. I would assume that the dealer probably doesn't know if it's been done or not, but I will check to see if they put a sticker on the engine to tell you about the timing belt. If it has not been done I will have the dealer do the timing belt and water pump @ 90k, but I will do all plugs, wires and fluid flushes and fills. I'm sure that you guys can help me if I have any questions. BTW, are the rear plugs that that in my eclipse, where they are hidden under the plennum?
Yeap that correct.
Postby Assyrian » Wed Feb 22, 2006 10:15 am
good luck!
-Edgar
A noobie with an 02 SEV6 MTX
Assyrian
