SolaraGuy.com • View topic - Just getting in under the wire
Postby MCOjerry » Thu Jun 14, 2007 4:45 pm
^Yes, I'm confusing the convertible with the coupe...not avail in 4cyl or manual at all.
Postby DoctorMark » Fri Jun 15, 2007 11:39 am
welcome!
DoctorMark
Postby theprodigy79 » Fri Jun 15, 2007 11:54 am
Welcome, enjoy the new toy!
theprodigy79
Postby Nyyankees3511 » Fri Jun 15, 2007 7:56 pm
Welcome to sg.
Nyyankees3511
Postby HarryAdventurer » Sun Jun 17, 2007 4:45 am
Thank you all for the warm welcome. Tomorrow, I go to the dealer to pick up my mats and license plates. After reading up on it on a Toyota trucks forum, I was finally able to correct the door locking situation. (You don't have to "shift into" park. Just leave it in park, and use the "engine off" chime to time the five seconds.) If the trip computer is correct, I'm averaging 28 mpg.
Well, that should be enough from me for now.
2007 Cosmic Blue Solara, 4cyl Auto
HarryAdventurer
Postby Gadgetjq » Sun Jun 17, 2007 5:46 am
HarryAdventurer wrote:On Wednesday I discovered that I cannot change the automatic door locking system following the procedure described in the manual.
Harry,
From your description it sounds like your lock/unlock toggle is the same as other gen2's. Mine ('04) works fine but you 'must' follow the instructions to the letter. I.E. if the manual says doors have to be closed or doors open then that's a condition. If you have to insert the key X number of times and turn the ignition on/off within a certain number of seconds then you can't be outside the parameter. You oughta see the hokey pokey that's required for toggling your alarm system between active and passive!!
Just for grins check out the third item on this page: http://www.gadgetjq.com/solara/mom.htm See if there's a step you've been skipping.
Cheers
Gadgetjq
Postby KSolara » Sun Jun 17, 2007 7:24 pm
Im a bit late but welcome to SG
Im glad to see another solara in jersey
o4 SE I4 Lunar mist
KSolara
