SolaraGuy.com • View topic - New Guy from Houston
Re: New Guy from Houston
Postby SteveSolara » Tue Mar 27, 2012 5:42 pm
Well any compound polish would work, just don't use lens cleaner they don't work, well not as well as compound polish does. You don't have to go get them super expensive one just a small bottle or something cheap, just has to be Compound Polishing. It basically a liquid sand paper mixed with polishing solution so it take off a thin layer of crap on the lens and polishes it too, unlike the lens cleaner that just clean and doesn't actually get deep down and lake a layer of dirt off, it just polishes.
To prevent it from happening again in the future you can use that wax that you had, after the compound to Seal in the compound and the lens itself.
Hope that helped, let me know how it turned out.
Image Image
SteveSolara
Postby nemx20 » Thu Jun 07, 2012 10:05 pm
kdmac015 wrote:which buffer and compund do you recommend? I used the turtle wax lens cleaner last time and it lasted a week. Was thinking about getting new/newer ones, trying the BHLM, and putting 3M protective vinyl on it, the clear stuff.
You can try using the 3M Headlight Restoration Kit. Not too pricey and it'll literally make your lenses look brand new.
    2000 SLE V6
    Injen SRI, Muffler
    K&N Oil Filter
    RP HPS 5W-30 Oil
    Yellow Fogs
    Smoked
    Plasti-Dip Emblems
    Debadged Trunk
YouTube: http://www.youtube.com/user/LaraModz
nemx20
Postby SteveSolara » Fri Jun 08, 2012 1:21 pm
meguire polishing compund
Image Image
SteveSolara
