SolaraGuy.com • View topic - Hi, everyone
Hi, everyone
Hi, everyone
Postby ThatVietGuy » Sat Jun 25, 2005 1:56 am
Hello, long time reader, just signed up.
Just a little bit about myself:
I live in Loma Linda, CA (in the Riverside area) and I go to U.C. Riverside.
I drive an automatic, BONE STOCK ( :( x 2) SE V6 Solara. The only things I really have done to it is an Ipod adapter for my deck and I also have an Infinity Basslink in the trunk. I like to autocross the Solara every now and then and I also hit the track (Buttonwillow or Willow Springs).
That's about all I can think of right now. Hope to get to know all of you sooner or later :)
P.S. I also try to "drift" the Solara every now and then :drinking:
ThatVietGuy
Postby Nutty101 » Sat Jun 25, 2005 2:02 am
How is it at the track compared to other cars?
Nutty101
Postby ThatVietGuy » Sat Jun 25, 2005 2:06 am
Depends what I'm up against.
I get annhilated by real V6's (i.e. 350Z).
I can pull away my friend's 240SX, and most other 4 bangers, pretty easily once I hit the straightaway, but he catches up immediately in the corners.
The Solara would be a lot better if I could get a decent suspension setup on it.
ThatVietGuy
Postby Nutty101 » Sat Jun 25, 2005 2:15 am
ThatVietGuy wrote:Depends what I'm up against.
What are you planning on going with? Are you getting issues with the rear going up in the air and sliding? I had that issue with mine before we did anything to it. Now I can get the rear wheel almost 2 to 3 inches in the air and have 0 chirp or ripping of the tires. Course my setup eats tires fast. Running a neg 3 camber on the fronts and around 2 on the rear. This is one thing the solara needs, once done your car will be something different. At really high speeds you can tell right away. On stock setup I would slide around 65 on a bridge by me. With my current setup I can push down 100 and not loose grip at all (unless it's wet. May be crazy but not stupid).
Going to go to a track in a few weeks. Be the first for me at one so I am kinda curious how well the car can do.
Nutty101
Postby ThatVietGuy » Sat Jun 25, 2005 2:35 am
The car is just too soft from the beginning.
From what I've read here, if I could get Tein or TRD springs plus Tokicos (or if I could somehow get coilovers), TRD RSB and FSB, and 225's in all four corners, I could corner MUCH better.
As for your first time, I say you enjoy it as much as you can because once you leave, you WILL have a very bad urge to go back ASAP.
ThatVietGuy
Postby Whatever » Sat Jun 25, 2005 3:26 am
do you go to UCR?? i go there once a while, so i might see you around :D
Whatever
Postby thealkimo » Sat Jun 25, 2005 3:29 am
welcome...
thealkimo
Postby ThatVietGuy » Sat Jun 25, 2005 3:31 am
Whatever wrote:do you go to UCR?? i go there once a while, so i might see you around :D
My Solara is pretty noticeable (UCR badge and a louder than normal exhaust). Say hi if you can :D
ThatVietGuy
Postby Paladin06Greg » Sat Jun 25, 2005 4:22 am
Welcome!! If you really want to tighten up that suspension check out the aftermarket section for 1.0 to 1.5 Gen Solara. There are a number of Rear Sway Bars, Front Strut Brace and front sway bar options that will help. You can also upgrade your springs, and struts as well.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Astro » Sat Jun 25, 2005 9:32 am
Get some coilovers!!!
Postby ptorican-king » Sat Jun 25, 2005 10:09 am
welcome to SG enjoy
1999 SLE Green stock SOLARA
ptorican-king
Postby 1st Gen Sol » Sat Jun 25, 2005 12:16 pm
Welcome to SolaraGuy......
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby CHRIS CLUTCH » Sat Jun 25, 2005 12:26 pm
Welcome. Keep us posted on mods and good luck with your ride.
CHRIS CLUTCH
Postby cdeez » Sun Jun 26, 2005 9:48 am
welcome and enjoy the site....
last standing...
Socalara...
cdeez
Postby NVDIS1 » Mon Jun 27, 2005 4:42 am
