SolaraGuy.com • View topic - Hello and Help
Hello and Help
Hello and Help
Postby RionsRun » Mon Aug 28, 2006 8:15 am
I am a female in California looking at a late model Solara SLE coupe. I test drove a 2004 with a suspension problem that pulled to the left. Was that fixed on the 2005 and 6 models?
I then became aware of a bad transmission lag and unexpected acceleration on the 2005 and perhaps later models per the included links.
Is the Transmission Shift Enhancement a workable solution, does it completely do away with the problem or is it a partial remedy?
I do not know that much about cars and would appreciate any help. I think this is a great looking car, right size, have seen worse gas mileage elsewhere but need to know the Toyota reliability is still there.
Thanks,
-Rion
CONSUMER COMPLAINT: ODI Case Number: 10118431
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Details: I RECENTLY PURCHASED A 2005 TOYOTA SOLARA V6...THE HESITATIONS ON ACCELERATION ARE UNMANAGEABLE AND DANGEROUS...SOMEBODY HAS TO FIX THIS PROBLEM...BEFORE THIS CAR CAUSES A SERIOUS ACCIDENT.*AK
Occurrences: 1 Injuries: 0
Fail Date: 04/23/2005 Deaths: 0
Date added to datbase: 4/25/2005
[FILE] your own complaint on this model car.
http://www.mycarstats.com/safetystation.asp
Toyota has come out with a fix for the 1 to 2 second delay on the downshift of their 5 speed transmission!!!!
I took my 2005 Solara to the dealer and got the "Transmission Shift Enhancement" installed and now the car shift perfectly.
Take your Lexus ES's, Tundras or Solaras and request the re-programming of the car's computer.
IT WORKS! I got installed yesterday, (8/2/06) and works perfectly.
Ernesto Guerrero
Posted at 10:54AM on Aug 3rd 2006 by Ernesto Guerrero 0 stars
http://66.102.7.104/search?q=cache:lcvz ... r-08-03-...
RionsRun
Postby SleeperSolara » Mon Aug 28, 2006 11:40 am
Welcome to SG.org
And to answer your question about the problem....... uh........
And only one i can answer is the suspension problem.
That is probably a bad alignment.
Postby DaTwUnKrAziEpInOy » Mon Aug 28, 2006 11:46 am
Welcome and ummm.... ????
DaTwUnKrAziEpInOy
Postby Solarafreek » Mon Aug 28, 2006 1:25 pm
Welcome to SG!
I am sure with all the Gen 2 members on the board you can get a lot of useful information to help you answer your questions.
Solarafreek
Postby Sebas007 » Mon Aug 28, 2006 2:07 pm
Welcome SG.com !!
TSB stands for Technical Service Bulletin
- Left pull on '04 and some '05 models is fixed with an available TSB.
- Transmission lag in the tranny is fixed on '04 and '05 models with an available TSB.
- Transmission lag supposed to be fix for '06 Solara V6...seems that it isn't right at 100% and no TSB available.
I own a '06 Solara SE V6 and I use a lot the "sportshift". I manage the gear the car has to be so no lag is possible. This car is one of the greatest bang for the bucks ever !! Lexus as a Toyota price...it's really is !!
If you can I would suggest you to get a '05 SLE V6 and get all the TSB done on it. You'll pay less and still have a recent car and have no problem as you described...or if you have a real nice deal on the '06 I wouldn't be too worry about the lag...
My own opinion :)
Postby Shoe » Mon Aug 28, 2006 2:33 pm
SleeperSolara wrote:i can answer is the suspension problem.
More complexed than that.
In 04/ 05 many a posts were made on the topic.
In the FAQ stickies forum they were all compiled the TSB lists are in this section of solara guy too.
http://www.solaraguy.org/viewforum.php?f=25
If you go with the 04 you test drove print off the fix for the left drift and get them to fix it before you buy it, and for the sake of trying tell them you think they should put a new set of tires on the car as well because you dont want a set that have been drifting left for 2/3 years.
shoe
Shoe
Postby RionsRun » Tue Aug 29, 2006 7:41 am
Thank you all very much. Armed with your expert advice I shall give this car a second chance. The Solara is too good and deserves another look.
-Rion
RionsRun
