SolaraGuy.com • View topic - New to Solaraguy
New to Solaraguy
New to Solaraguy
Postby yevhend52 » Sat Apr 07, 2007 9:03 pm
Hi everyone my name is Yevhen im about to turn 16 in a couple weeks. My parents will be giving me their 2000 V6 sle A/T. the car is stock but i plan on modding it but im not going to rush because i have time. the car has 108,000 miles on it no major problems yet, just had to replace a starter so far. a tune up wasnt done yet i have a couple questions
i have searched and i couldnt understand which sparkplugs to use. all i know is not to use bosch.
also do i need to replace the spurk plug wires if so the are NGK's good?
what else needs to be done for a tune up
last question. two days ago the drivers side window fell inside the door I took the door panel out and saw that the cable that pulls the window up and down snaped. Do i need to buy a new "pulley" system or just a cable. Do i need to call a dealer for this or can i buy it somewhere else.
Thanks you all for any information that you will give me and sorry that this is so long
yevhend52
Postby crispone » Sat Apr 07, 2007 9:06 pm
W-E-L-C-O-M-E ! ! !
You will find the help you need here! :wink:
Post some PICS!
Postby woa_its_j3ff » Sat Apr 07, 2007 9:16 pm
welcome. so many new kiddies comin in :D
Postby QuickSEV6 » Sat Apr 07, 2007 9:30 pm
Hello and welcome
Postby MCOjerry » Sat Apr 07, 2007 10:28 pm
Someone has had the widow problem, but for the life of me, I can't remember who. try searching around a little, you'll stumble on it.
I think the window just needed to be re-set, or the track replaced or something.
Postby combinationLock » Sat Apr 07, 2007 10:34 pm
hey welcome, fellow new solaraguy dude.
combinationLock
Postby unbalancedwood » Sat Apr 07, 2007 10:40 pm
Welcome!
I have no idea what is going on right now :)
unbalancedwood
Postby PXLpainter » Sun Apr 08, 2007 2:43 am
Welcome son. Wipe your feet before you come in and close the door behind you. Don't let the cat out. ;)
Postby NeFaRiOuS_SLE » Sun Apr 08, 2007 4:33 am
Welcome to SolaraGuy! Well incidentally, our search system is pretty much down at the moment... I couldn't find something I wrote 2 months ago :x ! Any decent spark plug (you're right, except Bosch) would work good as long as it's twin electrode, but that can be exempt when you use iridium spark plugs. As for the window issue, it is your regulator; I heard it's a b!tch to replace.
Other than that, good luck and enjoy your upcoming car!
Postby sahuddleston » Sun Apr 08, 2007 5:56 am
welcome to SG
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby yevhend52 » Sun Apr 08, 2007 6:21 am
thanks for all the welcomes
and thanks to NeFaRiOuS_SLE for all the info
2000 SLE V6
yevhend52
Postby Akfahad » Sun Apr 08, 2007 8:54 am
welcome aboard!
Postby Astro » Sun Apr 08, 2007 10:49 am
Welcome :D
Also, make sure the belts and water pump have been done!
Postby Paladin06Greg » Sun Apr 08, 2007 2:28 pm
Welcome!
Paladin06Greg
Torqued Solara
Torqued Solara
Postby **PoshPepper** » Mon Apr 09, 2007 8:28 am
Welcome to SG!
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
