SolaraGuy.com • View topic - New Member - KeepItSimpleStupid - 2000 SLE V6
Postby KeepItSimpleStupid » Mon Jun 18, 2007 11:26 am
My 2000 Solara is a Silver 2000 SLE V6, automatic with leather and traction control bought new. It also has climate control which I love. I'm currently running with Pierilli P400 tires. They are a nice tire for the buck. A friend did some tire research as well and ended up with the P400's as well. I had them on the Celica as well. Some guy I knew didn't like the way I could take corners, but he was perfectly happy driving his car above 100 MPH. I have about 60K miles on the car.
I haven't done any maintenence myself, but have had the following non-maintenence issues: rear rotors, both oxygen sensors and a battery. The dealership told me they don't check the battery water. WTF?
When the O2 sensor went bad the TRAC off control also illluminated for whatever reason. I had the dealership flush the brake system and install new bleeder valves. I need to get that done again.
My 60K service that I got last week cost about $1600. It also included the rear brakes and rotors and a coolant flush.
The only mod is the rearview mirror dimming and the hole in the seat from a scredriver in my back pocket. I had that fixed professionally.
I also had all the paint dings repaired professionally. Some idiot rear-ended me and did bumber damage. About $800 (INsurance paid) because they had to remove the bumper to paint it.
As for things I'd like to have (not in any order):
1. K40 radar detector
2. Class D sub-woffer.
3. Heated seats - Aftermarket systems available
4. Nav system
The impossible dream:
TRD supercharger and suspension kit, but I'd need the K40 first.
I owned an '82 Celica before this was with a manual transmission and did all the maintenence on the car from rebuild the carb, replace steering rack, installed AC from a box, replaced rear wheel bearings, full body work in prep of getting painted and the standard stuff. 237K miles and 17 years. I also replaced the clutch and replaced the crankshaft pully. Did valve adjustments every year.
The car never left me totally stranded that I needed a tow truck. One close call. I was driving near a bunch of junk yards. Car just died. I went to a Junk yard and repoved the ignition module from a later car. Modded it to work with a couple of jumpers and drove home.
A long time ago, I said I won't do exhaust systems, but I do check when they are done. The car didn't SOUND quite right so I looked at the newly installed muffer and the arrow was pointed in the wrong direction. I took it back to get fixed and it still didn't sound right and I look and agin it was backwards. I took it back the thired time and was told that the pipe was bent wrong and the kid that installed the muffler said it fit better that way.
I added a headlight on reminder of my design (Driver's door open and lights on = buzz). I installed an alarm system and power door locks. MACCO messed up the paint job by not using a clear coat that the paint system required and said it was my fault because I preped the car. I had the original front calipers when I got rid of the car probably because of flushing the brake system about every 3 years. Then the car was used as a getaway car after I sold it for two store roberies causing me a little grief.
Alarm systems don't work. They take a stereo and replace it pound for pound with Lentils. I guess my stereo and the Lentils were too much to carry. Or the alarm is going off in the parking lot in the rain and the thieves are running away.
I do one odd thing. I use Armor All on the hoses in the engine compartment. It makes them last a long time.
I always use anti-sieze and a torque wrench and petroleum jelly on light bulbs.
After my experience with the '82 and maintaining parent's and previous vehicles from Ford, Chrysler, Plymouth and GM. I'll stick with Toyota. They design a part. If it fails they re-design it. The parts are used in many models and therefore are available for a long time.
ME: Education in general engineering, self-taught for the most part machinist, EE design and troubleshooting skills, know many programming languages. Self-taught auto-mechanic (got to give Popular Mechanics a plug here), Small engine repair; Household anything: Plumbing, fixing a chimney, roofing, siding, etc.
KISS
KeepItSimpleStupid
Postby woa_its_j3ff » Mon Jun 18, 2007 11:42 am
i got lost somewhere while reading your thread. but
welcome to sg. enjoy your stay.
Postby sgunitkc » Mon Jun 18, 2007 12:08 pm
welcome to Solaraguy
seems like you have quite a unique background :D
sgunitkc
Postby PXLpainter » Mon Jun 18, 2007 12:43 pm
Welcome. :)
Postby Biggi_e » Mon Jun 18, 2007 12:50 pm
welcome to SG
Postby Paladin06Greg » Mon Jun 18, 2007 12:52 pm
That is one hell of an introduction but welcome anyway..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby RDKamikaze » Mon Jun 18, 2007 12:54 pm
Man, I hope your car is as detailed as your intro was. Post pics, please :).
Welcome to SG! :bday:
RDKamikaze
Postby NVDIS1 » Mon Jun 18, 2007 1:10 pm
Welcome :D
Postby kwyse » Mon Jun 18, 2007 2:14 pm
Thats a nice introduction/life story lol. Hope to see some pics up soon. Welcome to solaraguy!!
kwyse
Postby Akfahad » Mon Jun 18, 2007 2:56 pm
welcome
Postby KeepItSimpleStupid » Mon Jun 18, 2007 5:19 pm
Thanks guys. I have a few annoying things about the Solara to say something about:
1. You have to open the door to turn the headlights out.
2. No stock option to disable the auto-on mode of the headlights. I saw in a thread on Solaraguy that pulling the sensor cable on the right side will do it. I'd like to do that selectively. with a switch. Call it Drive-in movie mode. Oh, I forgot. Drive-in's are history although I there is one within 50 miles. http://www.delseadrive-in.com
3. Keys are a PITA to program. I've programmed two. Rule #1: Don't lose a master key.
4. Master/Slave keys are porely identifyable by color unless they are side by side. I engraved an "S" and an "M" on the metal part of the key.
5. Something I'd like to see on cars is the ability to open the door locks from inside the trunk. Ever had a passenger and say it's raining and you have to put something in the trunk. One of you get wetter. I'd rather open trunk then push button to open locks and your passenger gets in the car and probably both of you get less wet.
6. No Aux power connector in the trunk. I added that in my old car so that I could charge my laptop sight unseen. I'd like this to be either be selectable always on or on with ignition.
7. No trunk release on the keyfob. Somewhat negates #5 unless you have a primary and secondary car that you drive and don't carry a keyfob for the secondary car.
8. The can't lock your keys in the ignition is kinda cool except when you want to run the engine to clean off snow and keep the car locked. Carry 2 keys.
9. The Keyfob doesn't work if a key is in the ignition.
10. The Keyfob can't act as a "car finder". It doesn't have the range.
Is some of this Solara Trivia? You won't find it in the owner's manual.
KeepItSimpleStupid
Postby Down2TheC » Mon Jun 18, 2007 10:14 pm
lol... I love the irony between your name and your posts! You might consider switching to KIDD (= Keep It Detailed Dude.) 8)
Welcome.
Several of your pwaves about the Gen1 were fixed for the Gen2.
(1,2,4,7, maybe 10.)
Apparently they bugged other folks.
Down2TheC
Postby DoctorMark » Mon Jun 18, 2007 10:25 pm
welcome!
DoctorMark
Postby NeFaRiOuS_SLE » Tue Jun 19, 2007 12:38 am
Welcome to SolaraGuy!
1. ...Or switch off the light switch manually; usually if it's auto on, it should normally turn off within 2 seconds of turning off the engine.
2. Even then I usually just use the switch anyway; takes 30 seconds to kick in so it's almost useless unless you're driving around sunset. If you're going VERY short distances (I won't recommend this for more than 1/4mi), pull the hand brake up to the very first click before you turn the ignition to the ON position.
3. The dealership DO try to make it harder to program just to steal business from the guy that gives up and pays the "damned $$" for them to do it.
4. Good idea... Although my master keys are from a 3rd party, so look for scuffed up Strattec key vs. smooth Toyota logo valet key.
5. There's already something similar that I'm sure the mafia would hate to see in addition to the child safety handle that pops the trunk open from the inside :lol: ... But then again a remote trunk popper would be more of a feasable option.
6. I guess you can do the same thing that you did with your old car; rarely if ever does most cars do.
7. I agree on how big a pain in the aas that is, not to mention that my grandma's old '88 Chevy has it, and she has a car with manual locks/windows and no trunk light! However, there are kits that can integrate it into an aftermarket alarm.
8. Not as nice as Honda where you can ONLY lock it by key or remote, but still nice... I still suggest an aftermarket alarm with remote start; that way car thief bastards can't get far vs. keys in the ignition (guess which one insurances won't pay for?)
9. In ACC or just plain stuck in it still unlocks but you can't lock it... But all you gotta do is reach for the door and hit the manual power lock switch (almost an oxymoron ain't it?).
10. The Keyfob can't act as a "car finder". It doesn't have the range. Again, aftermarket alarms are the best... Even my SenCrap deserves some credit for having a dealer-installed Chapman where I got bored, held the trunk button down and actually managed to get it to pop from half a mile away! Yet frustratingly not only can't I do a remote opening of the trunk, sometimes it won't work further than 12 feet away (even on a fresh battery)!
Hope this Helps.
-Ed
Postby PXLpainter » Tue Jun 19, 2007 6:52 am
You should have gotten a newer Solara - the Gen 2's key fob will unlock anything from at least 100ft away. ;)
