SolaraGuy.com • View topic - Exhuast problemo!!!
Exhuast problemo!!!
Exhuast problemo!!!
Postby wid » Wed Mar 04, 2009 9:00 am
HEY u guys so today i was driving my car and i notice that when shoot of the line. i get sum hesitation and worse of all i hear and feel the exhaust like choking. what i mean by choking is that it sounds like all nasty like mouth lips flaping. and im not getting all my hoarse power of my 4 cylinder 2000 lara. :x i dont know think sumthing i wrong with the exhuast.
wid
Postby ToyoSolV6 » Wed Mar 04, 2009 12:03 pm
Bro you gotta post in the right section! :roll:
i hope someone can help you find your problem.
Postby D-money » Thu Mar 05, 2009 10:32 pm
SOUNDS LIKE A CYLINDER IS FOULED CHECK YOUR PLUGS
D-money
Postby 1gSE » Fri Mar 06, 2009 12:21 am
does it sound like a WRX?
Solara-M62 @ 5.5psi
1gSE
Postby solaraboy » Fri Mar 06, 2009 12:43 am
Sounds like a misfire. D-money's right check your plugs or plug wires.
solaraboy
Postby Midias » Fri Mar 06, 2009 5:01 am
Does it smell like rotten eggs maybe a plugged cat.
Postby wid » Fri Mar 06, 2009 8:25 am
1gSE posted : does it sound like a WRX?
^ lol it does!!!! but i changed my spark pluges and its a little better i see that i got more torque and found that cylinder # 4 was dead an now its working fine but i still feel and hear that WRX exhuast (choking sound). When i floor the gas pedal i get straight choking from the exausht. but when i start as light on the gas then i floor it its fine un till i get to like 50 mgh then thats when i dont get as much power to get up to higher speeds. I mean ill get to sixty and higher but it while take a little while.
wid
Postby gnegroni » Fri Mar 06, 2009 10:37 am
Now that you changed the plugs, shouldn't you replace the wires too?
gnegroni
Postby D-money » Fri Mar 06, 2009 10:48 am
i dont know your set up but it could be your intake if it is not your wires.if you are using an oiled filter you may need to clean your MAF meeter hope this will help
D-money
Postby Midias » Fri Mar 06, 2009 11:11 am
D-money wrote:i dont know your set up but it could be your intake if it is not your wires.if you are using an oiled filter you may need to clean your MAF meeter hope this will help
I think no MAF in the 00 4cyl solara. I would bet clogged cat or misfire. Any engine light or odd smells.
Postby D-money » Fri Mar 06, 2009 11:32 am
my car had the egg smell too i took it to ezlube and had them do an intake cleaning. smell is gone now horsepower restored
D-money
Postby Midias » Fri Mar 06, 2009 11:43 am
wid wrote:1gSE posted : does it sound like a WRX?
If you were dumping fuel into the down pipe you could have clogged your converter.
Postby wid » Sat Mar 07, 2009 2:30 pm
Im going to get the wires repalced. and i dont smell any eggs tho.But i think my problem does have to do with my intake becaise when i pop da hood i hear the intake gsping from time no time then the enginge jurks.
wid
Postby 1gSE » Sat Mar 07, 2009 5:26 pm
5 bux says the problem will go away when you replace the wires. I had the same problem with my old cavalier, sounded like a wrx, sure as hell didn't pull like one haha. Replaced them and it ran fine
Solara-M62 @ 5.5psi
1gSE
Postby wid » Mon Mar 09, 2009 12:41 pm
Umm were do u replace the wries at? :wink:
wid
