SolaraGuy.com • View topic - 99 solara strut problem
Postby thewade » Tue Sep 21, 2010 7:15 pm
I just bought a 99 solara v6. The back tires are worn on the inside apparently from bottoming out and rubbing on the spring plates. can i buy comprehensive units with springs included or should I look at other causes before spending the cash on new struts and springs
thewade
Re: 99 solara strut problem
Postby Toy1mzfe » Tue Sep 21, 2010 8:45 pm
i dont think bottoming out will rub spring plates.. i think the spring perch moves with the wheel and tires.
Postby ftw » Wed Sep 22, 2010 5:48 am
You need to give us some more information.
Is the car lowered? Is it on stock wheels and tires? If all the suspension and tire is stock then I cannot see that happening. It would most likely be an alignment problem or if the wear has a cupping effect, then its worn struts.
I had my tire rub the strut spring plates once, but it was because I had 17 x 8 wheels with a 235/45 tire and the offset was to high. Got a 10mm spacer and problem fixed.
New Daily: 2005 Corolla XRS
SOLD: DWP 1999 SE V6| Eibach/Tokico| Super Pro Dogbone Bushings, FSB Bushings| Energy Suspension Front Control Arm Bushings| Injen Intake
ftw
