SolaraGuy.com • View topic - Hi all
Hi all
Hi all
Postby akkinenidharmateja » Wed Jul 18, 2012 10:59 am
Hi,
I have a 2002 Toyota Camry Solara , 4 Cylinder Engine , 2 door coup not convertible. Car vibrates at a particular RPM and speed when accelerating and decelerating. The problem is observed at 2000RPM at low speeds when accelerating. What may be the possible problem ? .Please give the best solution.
Help is appreciated.
Thanks,
Proud Toyota Owner.
akkinenidharmateja
Re: Hi all
Postby PlateLunch » Thu Jul 19, 2012 11:12 pm
Howzit! Welcome, there is a great online library of info on the forum to search through. Sounds like a possible suspension mount problem, pretty common for this generation :)
PlateLunch
Re: Hi all
Postby GzNutz » Fri Jul 20, 2012 5:06 am
Welcome!
Re: Hi all
Postby SteveSolara » Fri Jul 20, 2012 11:24 am
Welcome! Have you tried to put it in park and rev it up to where you have the vibration at, and see if it vibrates. If it doesn't than it could be the tires or torque mount, suspension, or your brake system.
Image Image
SteveSolara
