SolaraGuy.com • View topic - Reverse lights
Reverse lights
Reverse lights
Postby ToyotaSolara » Wed Jul 25, 2012 8:04 am
Hello, I have a 2000 Toyota Solara 2.2 DOHC Automatic transmission and my reverse lights are not working.
I replaced the bulb then it worked, but I also had to replace the brake light bulbs, and when I step on the brake, the light indicator comes back on in dash, then when I had some one check my reverse lights again, they were not working. It seems to be a common problem with the switch at the transmission with the manuals, but it happens as soon as I step on the brake.
ToyotaSolara
Re: Reverse lights
Postby SteveSolara » Wed Jul 25, 2012 10:58 am
Have you checked your fuses?
Image Image
SteveSolara
Re: Reverse lights
Postby ToyotaSolara » Sat Jul 28, 2012 4:20 pm
Actually, I replaced the bulbs and now the light on the dash only goes on when I step on the brake, so I believe this is indicating that my brake pads are low and want replacing. (I also don't know where the fuses are, I don't have a chiltons for this car.)
ToyotaSolara
Re: Reverse lights
Postby SteveSolara » Sat Jul 28, 2012 4:48 pm
Fuses are under the driver side dash, behind the little pop out tray under the steering wheel
Image Image
SteveSolara
Re: Reverse lights
Postby 1gSE » Sat Jul 28, 2012 5:34 pm
check the fluid level while you're at it
Solara-M62 @ 5.5psi
1gSE
Re: Reverse lights
Postby SteveSolara » Sat Jul 28, 2012 5:47 pm
Yeah blinker fluid level can go out pretty quick
Image Image
SteveSolara
Re: Reverse lights
Postby dinoxor » Sat Jul 28, 2012 8:32 pm
Your owner's manual should tell you how to gain access and where the fuses are located
dinoxor
