SolaraGuy.com • View topic - New 2004 Sorara SLE V6
Postby glenb » Thu Jan 01, 2004 4:48 pm
Hi,
Love the Solara except the left turn problem.
Where is Toyota in finding a fix?
My dealer service dept. "fixed" the problem with adding 4psi to the left front tire. What a simple fix :(
I will wait for an official correction.
glenb
Postby RonF » Fri Jan 02, 2004 11:00 pm
Took my salara in for the left drift problem. They said the right rear wheel was out of alignment and brought it into specs. solved the problem.
RonF
Postby solara04 » Tue Mar 16, 2004 8:25 am
I got the below from a post on an anonymous site:
http://toyotaownersclub.com/forums/inde ... =8&t=6992&
I plan to hit up my tech manager about this problem and follow their recommendations. Even though I've almost gotten used to the left pull problem.
Your dealer should be able to correct the Left Pull with TSB ST002-04 but I have heard on a Web forum that it could increase tire wear (no idea if it's true or not). They refused to even attempt the fix on mine because it is a 2001 (identical design, identical symptoms).
Oh Lord.. won't you buy me a Solara Sport...
'04 SeSport Red, Moon Roof.
225 bhp @ 5600
Zero to 60 mph: 6.9 sec
Zero to 100 mph: 19.4 sec
solara04
Mookie's Buddy
