SolaraGuy.com • View topic - Tein springs don't fit on a 4cyl???
Postby Jon11582 » Mon Jul 26, 2004 6:51 am
I think shes uninformed. Suspension is exactly the same in the 4 and 6. And I know numerous 4cyls that have Eibachs on, so I dont see why teins shouldnt fit as well.
I have a 4cyl and I was also planning to get Teins in the future.
2000 Black Solara SE
Jon11582
Postby TadS » Mon Jul 26, 2004 7:36 am
Jon11582 wrote:I think shes uninformed. Suspension is exactly the same in the 4 and 6. And I know numerous 4cyls that have Eibachs on, so I dont see why teins shouldnt fit as well.
^^^ Yep. This is why most of us 4-cylinder guys build the suspension first :). The parts do exist for that (since we are pretty much balled for motor parts).
TadS
Postby Jackass-Jeff » Mon Jul 26, 2004 8:41 am
All Solara suspensions will fit
97-01 Camry
99-03 Solara
Most market as V6 only because they test fitted on the V6... so the spring rates are made for the weight of the 1MZ... other than that, it fits.
1GR-FE ftw!
Jackass-Jeff
Postby Jon11582 » Mon Jul 26, 2004 11:17 am
the 5sfe (99-01 I4) is pretty much as heavy as the 1MZFE (99-03 V6), so your drops probably going to be able the same.
I believe the 2AZFE (02-04 I4) is 200-300lbs lighter than either.
Jon11582
Postby Jackass-Jeff » Tue Jul 27, 2004 7:26 am
Jon11582 wrote:the 5sfe (99-01 I4) is pretty much as heavy as the 1MZFE (99-03 V6), so your drops probably going to be able the same.
Yup =P The 5S was only like 100 lbs lighter... so the drop on a 2AZ would be slightly weird (front is higher)
1GR-FE ftw!
Jackass-Jeff
Postby dan99solara » Tue Jul 27, 2004 10:03 am
TEIN's are GREAT springs.
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
