SolaraGuy.com • View topic - CAI Filter Replacement
Postby Paladin06Greg » Wed Aug 04, 2004 4:33 pm
:? OK, I want to replace my InJen CAI filter with a K&N filter, anyone know what filter I need? Perhaps you would recommend another brand..
Thanks all 8)
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Mole » Wed Aug 04, 2004 5:34 pm
KN has more than 1 filter that can fit, i believe. difference is fatness and length.
just find one that you like that is 60mm(diameter of the intake pipe) and things should be fine.
Postby Paladin06Greg » Wed Aug 04, 2004 5:39 pm
8) 8) Thanks.. Buttoning down the hatches here. Bad weather is coming.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby JoeB » Thu Aug 05, 2004 12:56 pm
Buttoning down the hatches? Greg, my son and I were out riding waves on our boogie boards last night in OC, MD. 8)
K&N filters are widely used and allow good airflow but I've heard complaints about them too. Gadget says they allow extra airflow at the cost of proper filtering. He said hold the filter up to the light and you'll be shocked at the size of the holes in the filter. He recommends Amsoil filters.
I'm not having a problem getting enough air into the sc. If you were restricted on air flow to the sc, you would see that you couldn't boost up to the pulley rating. For example, you have a 6psi pulley and can only boost up to 5psi, the problem might be air intake restriction. Until you have a problem with that, I'd stick with good quality filtering. -JoeB
JoeB
Postby Paladin06Greg » Thu Aug 05, 2004 4:09 pm
Guts and balls is all I can say. Although from the east coast, Maryland as a matter of fact, I left many years ago to see the world and serve the nation. Since retiring I lived in Greece for a few years and the rest of the time was in Arizona. No beaches there my friend. So the thought of things blowing over last night did not make me happy at all.
What we got was no more then a good rain.
OK, the filter. I have the 6psi pulley and it dos not hit 6psi. 4.5 to 5 at the most. She's in the shop for a dyno-tune and ASFCII install as we type. I'll give you the results Saturday. Sure hope she doesn't disappointment me. :( I been known to turn the old M4 loose and make things die. LOL 8)
JoeB wrote:Buttoning down the hatches? Greg, my son and I were out riding waves on our boogie boards last night in OC, MD. 8)
8)
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Mole » Thu Aug 05, 2004 4:53 pm
if there's rain comming, i suggest you go back to short ram intake.
Postby Paladin06Greg » Thu Aug 05, 2004 5:14 pm
8) Hey partner,
I don't have the extension yet. Waiting for them to be available..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Paladin06Greg » Fri Aug 06, 2004 4:54 am
8) I selected a slightly different one.
Thanks
Paladin06Greg
Torqued Solara
Torqued Solara
