SolaraGuy.com • View topic - Sensor In - Sensor Out Settings for AFC II in V6 Solara?
Postby Paladin06Greg » Fri Aug 06, 2004 11:19 am
8) OK, trying to get my AFC II installed and the dyno-tune done. I need to know that settings for Sensor in, sensor out and sensor calibrate and Apex doesn't have a clue.
Please Help 8)
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Hsakuragi » Fri Aug 06, 2004 2:07 pm
sensor type HW 11 /12/13/14/15 either one would be fine, but make sure it's HW!
In & out is 1
Hsakuragi
Postby Paladin06Greg » Fri Aug 06, 2004 2:11 pm
8) 8) Hey thanks very much.. Our first hook up and I owe you one..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Hsakuragi » Fri Aug 06, 2004 2:47 pm
no problem, my car with 5.5 and safc setup for about 6 months without a problem at all, hope it works out for you too. :wink:
Hsakuragi
Postby Paladin06Greg » Fri Aug 06, 2004 2:49 pm
Did you get any noticeable performance gain with the S-AFC?? :-?
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Hsakuragi » Fri Aug 06, 2004 3:27 pm
safc is not really for performance, that's just to stablize your fuel ratio since you have more boost than the stock 4psi.
You don't want your engine to blow up right? Or the knock sensor blew because u simply want more boost?
No easy boost...boost need $ :x
Hsakuragi
Postby Paladin06Greg » Fri Aug 06, 2004 3:36 pm
True but, attaining that balance can lead to an increase in performance. Just thought I'd ask.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Hsakuragi » Fri Aug 06, 2004 3:57 pm
oh then...yes, it gained perfomrance! u know just one part leads to other parts.
Hsakuragi
Postby Hsakuragi » Fri Aug 06, 2004 4:02 pm
Hsakuragi
Postby Paladin06Greg » Fri Aug 06, 2004 4:52 pm
:) OK, I'll post my results tomorrow, good or bad..
Paladin06Greg
Torqued Solara
Torqued Solara
