SolaraGuy.com • View topic - tein springs
tein springs
tein springs
Postby hari-bhari » Thu Aug 12, 2004 8:36 pm
do these look ok? how come two are small and two are big? tein gives the biggest, drop, right? i kno its been discussed, but im too lazy to run a search :roll:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33582
come on dude... you have been around this forum long enough. plz post in the correct forum!
hari-bhari
Postby indiglosolara » Thu Aug 12, 2004 8:38 pm
never base it on the picture... look at the part number then go to the website...
they always use that picture....
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Vi3tT3kNiqz » Thu Aug 12, 2004 9:21 pm
read that guy's feedbacks. He seems to be kindof a flake lately. I was going to buy those form him but I have doubts so I'd rather not.
Vi3tT3kNiqz
Postby boneezy » Thu Aug 12, 2004 9:55 pm
intrax gives the biggest drops.. staggered too
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby ChargedSolara » Fri Aug 13, 2004 12:39 am
The drop is quite low 1.7 front 1.5 rear, i believe.
i have the tein s-tech with tokico shocks set up, with 18x7.5 all around.
this causes some rubbing when going over big bumps, when i add myself and 2 other average weight people it starts to rub pretty badly, my rear fenders are already rolled as well. hope this helps you make decision..
2008 C6 LS3
ChargedSolara
Postby that1mexguy » Fri Aug 13, 2004 7:06 am
ChargedSolara wrote:The drop is quite low 1.7 front 1.5 rear, i believe.
Hey man, I need to get my rear fenders rolled as well... did you do it urself or did u take it to a shop to do it? and did it improve at all? let me know man cuz i have the same problem when someone is riding in the back, thanks
that1mexguy
Postby hari-bhari » Fri Aug 13, 2004 10:31 am
what exactly does rolling the fender mean. ill have to get this done probably. how much does it cost.
hari-bhari
Postby pythonjosh » Fri Aug 13, 2004 12:01 pm
I've got Teins and Tokicos on my 5sp V6. You won't need to roll your fenders at all. Just worry about what rims you want to roll on.
pythonjosh
Postby hari-bhari » Fri Aug 13, 2004 1:02 pm
pythonjosh wrote:I've got Teins and Tokicos on my 5sp V6. You won't need to roll your fenders at all. Just worry about what rims you want to roll on.
but you are on stock wheels right? im gettin 18x8s
hari-bhari
Postby ICrazyChrisI » Fri Aug 13, 2004 2:07 pm
Ive been told those are sorta soft springs as well?
ICrazyChrisI
Postby pythonjosh » Fri Aug 13, 2004 5:34 pm
Yeah, stocks. But I plan on getting 19x8's. Shouldn't be a problem especially of you're just getting 18's. I say just get the rims, and see if they rub or not. I don't even think they'd rub if you were riding on Tein SS's either.
Josh
pythonjosh
Postby ChargedSolara » Fri Aug 13, 2004 8:18 pm
rolling the rear fenders is shaving some of the inside of your rear fender, specifically the area that rubs against your tires when you hit a bump/dip in the road. this cost me 50 dollars at my local shop, and it reduced a lot of rubbing in the back, however with more than 2 total passengers my car will still rub, perhaps it has to do with the offset of my 18's, and i'm running 235/40/ combo as well.
2008 C6 LS3
ChargedSolara
Postby that1mexguy » Fri Aug 13, 2004 8:56 pm
ChargedSolara wrote:rolling the rear fenders is shaving some of the inside of your rear fender, specifically the area that rubs against your tires when you hit a bump/dip in the road. this cost me 50 dollars at my local shop, and it reduced a lot of rubbing in the back, however with more than 2 total passengers my car will still rub, perhaps it has to do with the offset of my 18's, and i'm running 235/40/ combo as well.
well i'm running on 18's, 225/40 combo and they rub too when i have at least 1 person in the back and if i take very sharp corners so I'm definitely going to roll them. But you are saying that occassionally they still rub??? :-?
that1mexguy
Postby 1jzgte » Fri Aug 13, 2004 9:11 pm
for the guys w/ 225/40/18.. what the heck is your wheel offset? i have +42 with the same tire sizes and i dont rub at all. Plus i have tein s-tech springs also
1jzgte
Postby hari-bhari » Fri Aug 13, 2004 9:42 pm
well obviously you're rubbing because you have 235! thas too wide buddy. it seems to me that if you have 225, and roll it, you should be fine for hte most part. a little rubbing isnt going to do severe damage right?
hari-bhari
