SolaraGuy.com • View topic - strut mounts
strut mounts
strut mounts
Postby ulikepoi » Thu Aug 12, 2004 9:40 pm
I had Tokicos installed before the mechanic did not tell me the strut mounts were the ones that were bad, not the shocks. I have the clunk
problem still. The dealer said warranty expired even though it was a factory problem. How much is the part item and where can I get them?
Help.
ulikepoi
Postby geminimouse » Thu Aug 12, 2004 10:00 pm
Goto ur local toyota parts center.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby bkp_duke » Fri Aug 13, 2004 5:57 am
Part is around 90 for aftermarket and 115 or so for OEM. What will really suck is the labor. The strut assemblies have to be completely removed to install the mounts. Several hours worth of hard work.
2000 Solara SLE V6, Silverstream Opalescent
TRD Body Kit, Charcoal Leather
TRD Shocks, Struts, RSB, and Air filter
Legal Tint (32%)
bkp_duke
Postby pythonjosh » Fri Aug 13, 2004 12:05 pm
I've got the same problem. Toyota told me $111 per strut mount. Schuck's/Kragens/Checkers only carries the front strut mounts, not the rear. Toyota is the only place I've been able to find these and I'm still looking. Aftermarket? Where?
pythonjosh
Postby bkp_duke » Fri Aug 13, 2004 12:08 pm
not sure, the local shop i got to do the work got aftermarket for the front right (don't know about the rears)
Legal Tint (32%)
bkp_duke
Postby pythonjosh » Fri Aug 13, 2004 5:37 pm
bkp_duke wrote:not sure, the local shop i got to do the work got aftermarket for the front right (don't know about the rears)
Would you be able to get some info from them on a set of rear strut mounts for me? Just to verify, I need the part at the top of the spring that the strut goes thru and has the three bolts on top. Thanks,
Josh
pythonjosh
Users browsing this forum: Google [Bot] and 56 guests
