SolaraGuy.com • View topic - Question - Intake, safc....
Postby Hsakuragi » Thu Aug 12, 2004 11:34 pm
I just brought the injen intake, if i'm luckly can find the extension and installed. Do I need to readjust the safc ii since it's already installed with the 5.5 pulley?
So far no one gets an CEL for the CAI intallation right? *knock on the wood real hard*
Thank y'all!
Hsakuragi
Postby JoeB » Fri Aug 13, 2004 6:30 am
My experience is that you will not need to readjust the S-AFC. Although the air is cooler, it is the same volume of air so it didn't make any difference for me. The initial tune on the S-AFC is probably done with the hod up on a dyno so there isn't a build-up of hot air under the hood. Otherwise, although it would be the same volume of air going through the tube, it would be expanded due to the heat and be less burnable O2. The long-winded version of "no". :wink: -JoeB
JoeB
