SolaraGuy.com • View topic - clear corners
clear corners
clear corners
Postby eugene5786 » Sun Aug 15, 2004 10:14 am
i bought a pair from procarparts.com. they fit, but badly. anybody know hwere a good pair can be bought?
eugene5786
Postby Vi3tT3kNiqz » Sun Aug 15, 2004 10:30 am
ebay. mine fit perfectly. or try to custom it yourself from your OEM corners.
Vi3tT3kNiqz
Postby Solaradude » Sun Aug 15, 2004 11:42 am
yea some people get bad ones some people get good ones
u should try using dremmel for that perfect fit.
I will bankroll your poker career!! visit www.instant-bankroll.com
Solaradude
Postby MalBandito99 » Sun Aug 15, 2004 12:36 pm
this is a weird item because even after taking out my stock corners and just putting them back in, the right side one didnt fit properly, yet it was fine before I took it out. And I pushed it in right, jiggled it, everything to try to make the rubber lining fit flush again like it did before.
Corners are tough to make perfect. Just be happy with it, and use some extra clear silicone if you are that paranoid, its not like they will get flooded with water from the outside unless you totally submerge them in water, and then you got other problems at that point. :x
MalBandito99
Postby Jaimster » Sun Aug 15, 2004 2:20 pm
Won't fit if you have a Gen 1.5 Solara, you gotta modify the lamp. What year is your car?
Jaimster
Postby Dawgz » Sun Aug 15, 2004 2:28 pm
lol, im glad i did my own clear corners, saved myself like 27 bux....
Postby WTF?? » Sun Aug 15, 2004 4:04 pm
file down sum of the plastic on the inside where it gets caught from preventing you to have a good fitment...
sealing it up is a good idea too especially if ur in an area that rains a lot
Retired... its been fun Image
WTF??
Postby pythonjosh » Sun Aug 15, 2004 4:28 pm
I've had 3 sets of afermarket light housings, 2 corner (1 clear, 1 black), and my altezza tail lights. And NONE of them fit perfectly. Doesn't surprise me at all. Even if you're buying OEM corners. As Solaradude said, get yourself a dremmel and make it fit to your liking.
Josh
pythonjosh
Postby Dawgz » Sun Aug 15, 2004 4:56 pm
solara nytez wrote:file down sum of the plastic on the inside where it gets caught from preventing you to have a good fitment...
thanx, by the way i used my dremel with the extension for the one thats a bit further than the other one...came out good, all i need now is a mirror finish touch up paint
Postby dsmman » Mon Aug 16, 2004 9:25 am
is it standard for you guys to replace the whole assembly or has any one just removed the yellow plastic from the stock piece?
Twilight Blue 01'
6cly, 5spd, supercharged
Eibach 1.6
TRD short throw/strut bars
TRD exhaust
dsmman
Postby WTF?? » Mon Aug 16, 2004 1:05 pm
dsmman wrote:is it standard for you guys to replace the whole assembly or has any one just removed the yellow plastic from the stock piece?
most of us chose to replace them since removing the yellow reflector has a good chance of cracking the OEM lenses
plus it gives you the choice of going back to stock a lot easier
WTF??
