SolaraGuy.com • View topic - 19x7.5 +45 offset would rub??
Postby Ryan » Tue Aug 31, 2004 6:33 pm
I really need to know if a 45 offset on a 19x7.5 wheels will rub on our Solara??? I just got this great deals on Volkner wheels I just need to know if it will fit our Solara thanks - Ryan
Ryan
Postby indiglosolara » Tue Aug 31, 2004 6:49 pm
7.5 should have a 42 offset. 45 offset is cutting close. you may need a 2mm spacer for the rear, but the fornt will be fine...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Ryan » Tue Aug 31, 2004 8:08 pm
iazuncupidi wrote:7.5 should have a 42 offset. 45 offset is cutting close. you may need a 2mm spacer for the rear, but the fornt will be fine...
hmm.. really maybe the guy just gave me the wrong offset so all 7.5 wheels has a maximum of +42 offset??? is this correct?
Ryan
Postby indiglosolara » Tue Aug 31, 2004 8:13 pm
not the max, but with my experience with 7.5" width with 45 offset your just cutting it close. also depending on the tires your getting. I know that 225/40 was giving me a little bit of rubbing with my old set. i used a 2mm spacer to keep it away from the struts.
right now i have 42offset with 225 tires and i dont have a problem. its about 3 to 4 mm away from strut. right now i just adde a 2mm spacer inthe rear just to push out the rims a little bit to make it look more flush. so its sitting about 5 to 6 mm away from the struts.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Ryan » Tue Aug 31, 2004 8:21 pm
would this be problem to 18" wheels w/225/40 too? or it's another story?
Ryan
Postby indiglosolara » Tue Aug 31, 2004 8:34 pm
it wouldn't matter if it was 15 or even 18... since the offset is how far the wheel will sit inward or outward...
its going to be the same
indiglosolara
Solara 2 xB
Solara 2 xB
Postby ICrazyChrisI » Tue Aug 31, 2004 8:49 pm
Also depends what size rubbers you got on
ICrazyChrisI
Postby indiglosolara » Tue Aug 31, 2004 8:58 pm
ICrazyChrisI wrote:Also depends what size rubbers you got on
yup.. already mentioned it...
indiglosolara
Solara 2 xB
Solara 2 xB
