SolaraGuy.com • View topic - rotors
rotors
rotors
Postby s15lara » Thu Sep 16, 2004 1:29 am
does any1 know the part number for the cross drilled and slotted rotors for the 99 v6 se solara? i wanna get them from brembo, but my dad told me that he plates the rotors for certain companies and told me that he could get me all 4 for free. good idea/bad idea? what companies are reliable? he told me to get the part number but i had no idea how to get it. let me know guys...
s15lara
Postby bkp_duke » Thu Sep 16, 2004 3:25 am
Brembo doesn't make cross drilled AND slotted rotors, it's either cross drilled or slotted.
As to why . . . I'm too lazy to type. Use the search function. :drinking:
2000 Solara SLE V6, Silverstream Opalescent
TRD Body Kit, Charcoal Leather
TRD Shocks, Struts, RSB, and Air filter
Legal Tint (32%)
bkp_duke
Postby krawzyazn » Thu Sep 16, 2004 8:32 am
theres a company that gets brembo blanks and makes them cross drilled ans slotted and they can come platted
Postby Yanks0114 » Thu Sep 16, 2004 8:48 am
Brembo only sells cross drilled or slotted. As was said above, the only way to get xdrilled and slotted is to have a machine shop do it
Postby s15lara » Thu Sep 16, 2004 8:53 am
ok, so then they only make the xdilled or slotted. does any1 have the part number for either? rear and front? cuz like i said, my dad is going to get them for me but he needs to know the part number.
s15lara
Postby MalBandito99 » Thu Sep 16, 2004 10:23 am
Plain brembo rotors are fine too. The slots might help, but not tremendously. There is more cosmetic effect with those rotors, if people are looking that close at your wheels; thats all I see in them.
MalBandito99
Postby Hsakuragi » Thu Sep 16, 2004 10:53 am
SEARCH....www.tirerack.com
Hsakuragi
Postby impactX » Thu Sep 16, 2004 11:38 am
Brembo does NOT sell any x-drilled or slotted OEM replacement rotors. Machine shops buy Brembo Blanks and do it.
The puny stock rotors were bad enough as they are, once you slot/drill them, they become even worse.
I suggest anyone who wants good stopping power to buy EricSol's big rotor kit.
impactX
Postby Yanks0114 » Thu Sep 16, 2004 12:17 pm
Impact, Brembo does offer Xdrilled or slotted as part of their sport line
"The Brembo Sport discs are premium OEM replacement units that meet or exceed all vehicle manufacturers’ specifications and tolerances. They are fully compatible with stock calipers wheels and other chassis components, easily mounting onto the vehicle. The brake discs are built in high carbon cast iron and they are available either drilled or slotted. The brake discs are then planted for corrosion resistance and for a bold, aggressive appearance. "
Postby s15lara » Thu Sep 16, 2004 12:22 pm
ok, so we are all agreed that they do make them right? so what would be the part number? how would i be able to tell my dad which one to get out of all the ones that he plates? im lost here guys, help me out...
s15lara
Postby Yanks0114 » Thu Sep 16, 2004 12:27 pm
check tirerack.com or any other retailer that sells them for a part number
Postby ICrazyChrisI » Thu Sep 16, 2004 5:58 pm
impactX wrote:Brembo does NOT sell any x-drilled or slotted OEM replacement rotors. Machine shops buy Brembo Blanks and do it.
They do :D I posted the same thing till I checked out tireracks site. I quickly deleted my post after that.
ICrazyChrisI
Brembo Big Brake Upgrade for Solara
Postby TRD_solaRa » Sun Sep 19, 2004 1:32 pm
I found this . . . http://www.geocities.com/afanasyev.geo/SolaraBrembo.html
Brake Kit Includes:
* 330x30 mm Cross Drilled or Slotted Discs
* Brembo Four Piston F50 Calipers
* Stainless Steel Braided DOT Approved Brake Lines
* High Performance Brake Pads
* Billet Aluminum Mounting Brackets
* Mounting Hardware
Brake kit works with 17", 18" and 19" Wheels. Depending from your wheel design you might have to use H&R Spacers to provide enough clearance for Brembo caliper. Calipers can be ordered in Black, Red or Silver. High Performance Brake Pads included with the kit are suited for high end street use as well as light track application. Kit works with standard Master Cylinder and doesn't affect ABS or Traction Control.
MSRP: $1895
TRD_solaRa
Postby Yanks0114 » Sun Sep 19, 2004 4:20 pm
I don't think that kit is available any more. It was custom made and was never a huge seller. Its also $1900 for just the fronts.
Postby TRD_solaRa » Sun Sep 19, 2004 5:05 pm
awwwwwwwwwwwwwwww man . . . crappy deals :x . thanx for the update yanks ;). shooooootz.
TRD_solaRa
