SolaraGuy.com • View topic - Gen 2 17" Wheels
Gen 2 17" Wheels
Gen 2 17" Wheels
Postby sleepin2000 » Sun Sep 19, 2004 7:53 am
I've searched around and it sounds like I won't need spacers in the front but will need 5mm spacer in the back is that correct?
In Memory of My Son
Christian Edward Goldstone
October 13, 2005 - June 7, 2007
sleepin2000
Postby Astro » Sun Sep 19, 2004 8:58 am
You might be able to use 10mm. If you use 15mm, you will have to use wheel stud extenders.
Postby sleepin2000 » Sun Sep 19, 2004 2:38 pm
Alright, if I understand correctly, the gen 1 has a offset of +43mm and the gen 2 has an offset of +40mm(?). So does that mean I would need a 3mm spacer to offset the rim from the strut?
In Memory of My Son
sleepin2000
Postby ICrazyChrisI » Sun Sep 19, 2004 6:37 pm
I just put the 15mm hubcentric spacers/extended wheel studs in the back for the added safety. I dont want my wheels/tires to rub against anything, and I want as much thread in my lugnut possible.
ICrazyChrisI
