SolaraGuy.com • View topic - Intake's
Intake's
Intake's
Postby manwithhoe » Fri Oct 01, 2004 8:08 pm
Anybody know of a good intake for the 4cyl.? I saw injen had one but it was mad expensive, anybody else? Also which are better eibach or TRD lowering springs?
manwithhoe
Postby Fletch » Fri Oct 01, 2004 8:25 pm
The stock intake is good...
Eibach's are easier to come by but have a larger gap in front then back. I think the Tien's are an even drop.
2006 Legacy GT spec.B
Fletch
Postby s e y t o n » Fri Oct 01, 2004 10:10 pm
:n00b:
-Sam
Black 2000 5s-fe 5 speed - "Blackie"
s e y t o n
devilish solaraguy
devilish solaraguy
Postby Akfahad » Fri Oct 01, 2004 11:10 pm
do some searches man...before people start to jump on you
Postby Hsakuragi » Fri Oct 01, 2004 11:25 pm
:snipersmile: :n00b: :vamp:
u don't want to see this happen :wink:
Hsakuragi
Postby 2002greenhornet » Sat Oct 02, 2004 12:08 pm
The Teins drop 1.4" in the back and 1.7" in the front.
Steve
2002 SLE V6
2002greenhornet
Postby s15lara » Sat Oct 02, 2004 6:00 pm
it also depends on what you are looking for. if you want the springs and only springs and decide to get struts later, then i would go with the teins. but if you just want to get it all done in one hit, then i would recomend the tein coilovers...thats what i have and i love it.
s15lara
Re: Intake's
Postby onefiend » Sun Oct 03, 2004 9:01 am
manwithhoe wrote:Anybody know of a good intake for the 4cyl.? I saw injen had one but it was mad expensive, anybody else? Also which are better eibach or TRD lowering springs?
There's a cheap short ram intake by Pro car parts, but people have had issues with this product...Just get a K&N drop in air filter if you cant afford the Injen and CAI extension.
TRD springs are made by Eibach, but for some reason the Eibachs leave you with a smaller wheel gap compared to the TRD springs. Tien springs will have you really low to the ground but are cheaper than Eibach and TRD.
onefiend
