SolaraGuy.com • View topic - Setting tire pressure
Postby all_red » Tue Oct 05, 2004 9:40 pm
Do yall stick with the 32psi Toyota recomends?
I used to do that with stock tires. Now I have different size tires, and was wondering how to find out the best tire pressure. Any input is appreciated!
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby Mole » Tue Oct 05, 2004 10:13 pm
the MAX psi is labeled on your tire. just hunt for it.
most likely its either 44 or 51, but don't believe it till you see it on your tire.
then obviously, cooler climates, you can go more since air is more dense and warmer climates less since heat expands.
