SolaraGuy.com • View topic - JIC FLT-A1US KG?
JIC FLT-A1US KG?
JIC FLT-A1US KG?
Postby adam2562 » Wed Oct 06, 2004 8:38 am
why is it that i find on some sites, it refers to the shock kg as being 7kg in the front and 5kg in the rear yet when i look elsewhere and there i a JIC application list i see that it says 8kg in the front and 6kg in the rear.. and when Peter has his FLT-A1US for sale when he never installed it the box had written on it from te picture 7kg/5kg i'm confused as to what it is.. any help appreciated and Peter if u read this.. i need to get in contact with you bout the JIC's[/b]
Adam - 99 V6 5spd 165k -SOLD
adam2562
Re: JIC FLT-A1US KG?
Postby TRD_solaRa » Wed Oct 06, 2004 1:03 pm
Adam2562 wrote:why is it that i find on some sites, it refers to the shock kg as being 7kg in the front and 5kg in the rear yet when i look elsewhere and there i a JIC application list i see that it says 8kg in the front and 6kg in the rear.. and when Peter has his FLT-A1US for sale when he never installed it the box had written on it from te picture 7kg/5kg i'm confused as to what it is.. any help appreciated and Peter if u read this.. i need to get in contact with you bout the JIC's[/b]
The JIC applications are built and made for the streets of Japan . . . the roads in the United States are fricken horrible compared to them, thus a different application. I'm not sure which is which tho (the one for Japan and US). I'm guessing that the 7kg F & 5kg R is meant for the US Spec., but depending on where you're reading it from the 8kg & 6kg could be wrong. I'd jus trust the JIC Magic website. http://www.jic-magic.com/
Here's the application list: http://www.jic-magic.com/Library/susapp/flta1susp_app.htm
TRD_solaRa
Postby adam2562 » Thu Oct 07, 2004 3:27 pm
thanks
adam2562
