SolaraGuy.com • View topic - SPEC Stage 3 clutch & lightweight flywheel installed
Postby Fletch » Mon Oct 18, 2004 10:05 am
Clutch pedal effort is slightly stiffer, but it feels good. Shifts are clean & controlled, the friction point is closer to the firewall so creeping in 1st gear takes a little more concentration.
There is a noticable improvement in power with the aluminum flywheel. It is not a huge difference but it definately wraps out more quickly.
I don't know what brand the flywheel is, it might be SPEC... I would definately recommend this set up, I got it at a decent price through horsepowerfreaks.com
2006 Legacy GT spec.B
Fletch
Postby s15lara » Mon Oct 18, 2004 3:21 pm
how much did the setup cost? i need a new clutch and was looking for a new one.
s15lara
Postby Fletch » Tue Oct 19, 2004 4:36 am
Clutch: $337
Flywheel: $286
Shipping: $35
Fletch
Postby Keg-Of-Iron » Tue Oct 19, 2004 11:00 am
So you said w/ the aluminum flywheel you felt more power, what about w/ the Spec 3 clutch?!!? Or did you install it all at the same time? Your set up is kind of like mine and i just wanted to know if you felt a considerable difference for the cost.
FIGHT ON U.S.C.!!!
2000 SE v6 5spd Supercharged! 6 lb. pulley...
http://www.cardomain.com/memberpage/510493
Keg-Of-Iron
Postby thealkimo » Tue Oct 19, 2004 3:32 pm
Fletch wrote:Clutch: $337
Flywheel: $286
Shipping: $35
don't forget install...can be $300+ w/out hookup
unless you can drop the tranny yourself :wink:
thealkimo
Postby toy4x4boy » Tue Oct 19, 2004 4:14 pm
Did u do it yourself or have a shop do it? If a shop, what shop? I'm not too far from you and info like this would be beneficial for the future. 8)
toy4x4boy
Postby Fletch » Tue Nov 23, 2004 6:45 am
Both were installed at the same time. I have a local independent mechanic that I have known for about 7 years, he done most of the work on my car.
The only downfall about the clutch/flywheel setup is there is a much smaller window for the friction point than stock. Takes some practice not to bog or burnout with a quick start in 1st.
BTW, 1st gear wraps out real quick. Can't use full throttle or you just smoke 'em.
Fletch
Postby Mole » Tue Nov 23, 2004 9:15 am
sounds similiar to puc clutches.
did spec ever make a flywheel for our trans?
Users browsing this forum: Google [Bot] and 27 guests
