SolaraGuy.com • View topic - Bigger Brake Caliper
Postby SleeperSolara » Wed Oct 20, 2004 8:48 am
Ok i know this forum has talked about using Supra calipers.
But i was wonderin' if i could use the Supra brake calipers on my stoc rims.
In other words us the Supra brake caliper wit my stock rims.
Will it fit??
Is the Supra stock brake caliper work.
If they do fit what else do i need to put them on.
Could i just use the Solara brake booster, and lines??
Postby Yanks0114 » Wed Oct 20, 2004 10:18 am
No one has been using the supra caliper. Members have been using ericsol's kit which uses a supra rotor and the stock solara caliper
You can not use it with stock rims. You must have atleast 17". I believe the rotor is 13"
If you want to use the stock wheels, just get upgraded pads and Stainless steel brake lines
Users browsing this forum: Google [Bot] and 42 guests
