SolaraGuy.com • View topic - bad speaker
bad speaker
bad speaker
Postby Dawgz » Wed Oct 27, 2004 10:04 pm
Hey i just noticed that sometimes my rear (driver side) messes up, anyone know where i can find an identical speaker like this'? or somthing liek this? and how hard\easy is it to replace?
Postby ChargedSolara » Wed Oct 27, 2004 10:06 pm
i believe our speaker in the back is 6x9, do you have the stock JBL system? might as well just buy aftermarket ones..they sound better.
2008 C6 LS3
ChargedSolara
Postby HKSV6SLE » Thu Oct 28, 2004 12:54 am
get aftermarket. :drinking:
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Dawgz » Thu Oct 28, 2004 9:37 am
yea mine is stock, but if i buy an aftermarket speaker, wont it sound diff since im only replacing one?
Postby pythonjosh » Thu Oct 28, 2004 9:47 am
Dawgz wrote:yea mine is stock, but if i buy an aftermarket speaker, wont it sound diff since im only replacing one?
Just replace both dude. Like a week after I bought the car I blasted a Bone Thugs CD and blew out the same speaker. I just bought a set of Jensen 6x9's with built in tweeters. Just about any aftermarket will sound better than the stock jbl.
pythonjosh
Postby SleeperSolara » Thu Oct 28, 2004 9:52 am
Yeah i agree wit Pyhtonjosh, when you replace you speakers always replace both of them, even thought if one of the speakers are messed up.
Also make MDF speaker mounts for t he rear.
Cause i'm usin' the factory speakers mounts for the rear and they sound sssoooooo bad.
The front speaker mounts work good.
Postby Dawgz » Thu Oct 28, 2004 2:23 pm
Postby ZXLNT » Thu Oct 28, 2004 11:33 pm
I like the infinitys myself..
ZXLNT
Postby Turbosolara » Fri Oct 29, 2004 1:38 am
speakers are always come in PAIR.
if the speaker is high output and you dont have amp to push it, it will sounds funny because under power.....
Postby HKSV6SLE » Fri Oct 29, 2004 4:00 am
replace them both and like everyone said anything is better than stock. for the rears you can always use the factory mount for the rear deck. my aftermarket fosgates are under the factory jbl grilles. :drinking:
www.lexusnet.com
HKSV6SLE
Postby SleeperSolara » Fri Oct 29, 2004 7:12 am
Go wit infiniti.
Pioneer speaker sucks they don't push out the dbls that loud.
Also not alot of good bass reponse.
My alpines put out a better bass response.
Also if you get aftermarket for the rear you should make speaker mounts the JBL stock ones suck in the back.
The fronts are good.
Postby jazzlara » Sat Nov 13, 2004 12:18 pm
ok, if you want sound performance go wit...
infinity 12" (2) subs (either fo two newest models)
MB Quart front component speakers
Alpine 3 way 6x9's in back.
2 channel above 600 watts amp to drive subs
4 channel above 800 watts amp to drive interior speakers....
...done and done
of course there are always other options.
jazzlara
Postby MalBandito99 » Sat Nov 13, 2004 3:19 pm
Good advice, guys. I blew mine out before I put my system in, over a year ago now. First the right rear went, sounded like a rattling junk, got me so pist. Stuffed it with paper towel and unplugged the speaker, the rattling stopped. Then a day later the left one blew. I just ripped both speakers out since its such a biaatch to take them out properly. Using some heavy duty garden scissors and grindin them til they were dull, I cut every little metal framing piece that held them in. Now its just gaping holes for the sub in trunk to flow into the cabin.
MalBandito99
Users browsing this forum: Google [Bot] and 27 guests
