SolaraGuy.com • View topic - Supra calipers strong????
Postby SleeperSolara » Thu Nov 04, 2004 10:30 am
I was wonderin if the Supra calipers were strong than our Solara calipers??
Wouldn't the Supra calipers bolt right up to ours??
The stock rims of the Supra is 16 i believe.
I was just wonderin' if the Supra calipers were strong if the are, and bolt right up to our brake pad brackets than that would be sweet.
And i would try to find Supra calipers for the front to change wit mine. :drinking:
Wait i just thought of this if the Supra calipers are bigger than i would have to change the brake pad brakets too. :evil:
Wouldn't my idea work??
Postby Mole » Thu Nov 04, 2004 10:37 am
no they are not the same and will not bolt up to the solara's brake system.
stock supra are 17'
bigger pads as well.
Postby TadS » Thu Nov 04, 2004 1:16 pm
If you ever can get it to work, please share the information.
TadS
Postby adam2562 » Thu Nov 04, 2004 9:28 pm
Non-turbo Supras have 16's by theway so that would be possible.. it is possibly a different caliper than the turbo version but i'm sure it still might be better
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby Turbosolara » Fri Nov 05, 2004 2:42 am
i dont know about the non turbo but the turbo version has 4 piston in the front brake. our solara has only one piston. If you want to retro fit the brake on your solara, it will be really expensive. i think you need to calculate carefully that how big is the brake reservor you gonna use and the fabricate brackets.
Postby SleeperSolara » Fri Nov 05, 2004 9:20 am
Yeah i guess......
Just wonderin' if it would work.
I guess alot of fabrication work to do.
Postby Mandarinsolara » Sun Nov 07, 2004 1:12 am
the custom work fittin them on would tower over the price of the product, no moron would spend a grand or two make a 200 dollar piece of junk fit. you go get real stuff, wilwood or brembo 6 pots, and 13" slotted/drilled rotors
Mandarinsolara
Postby TadS » Sun Nov 07, 2004 7:42 am
I wonder if there would be a way to get an aftermarket caliper to fit Eric's kit, since it allready allows you to use a Supra TT rotors.
TadS
Postby impactX » Wed Nov 10, 2004 12:57 am
TadS wrote:I wonder if there would be a way to get an aftermarket caliper to fit Eric's kit, since it allready allows you to use a Supra TT rotors.
It won't.
I already thought about getting the Supra TT calipers, it won't bolt up for sure and there are other issues.
Even with 1 piston, Eric's big rotor kit makes a huge difference in terms of braking.
impactX
Postby TadS » Wed Nov 10, 2004 6:59 am
What about a Wilwood, or another caliper maker? I agree that Eric's kit works very well. Everyone here w/ 17"+ wheels should get it, as it's very affordable.
TadS
Users browsing this forum: Google [Bot] and 25 guests
