SolaraGuy.com • View topic - Struts on ebay , whats your opinion
Postby camcar se » Mon Nov 08, 2004 6:41 am
I really want these so keep it low if possible, I need your expertise, would these be a good purchase, Heres my questions
1. I thought TRD stuts where just tokico's this says bilstein is that ok.
2. Would these be good struts, close to tokico performance anyway.
3. Can I use this with lowering springs, or will they not work.
4. is it ok that they are so rusty, do they look ok.
sorry but the guy selling them didnt give much info, thanks
here is the link http://cgi.ebay.com/ebaymotors/ws/eBayI ... Track=true[url][/url]
camcar se
Postby sunrise_solara » Mon Nov 08, 2004 7:22 am
The seller is not giving much information...Why? Looks like they must have come from a wreck, so there's one strike against them. That means they have been sitting for a while, strike two. They are misrepresented and without a detailed description, STRIKE THREE... :wink: They may be ok, but why take a chance? Tokikos are the way to go, so shop for the best price...
sunrise_solara
Postby TadS » Mon Nov 08, 2004 7:40 am
TRD = Blisten on the Solara.
They are a little rusty, but that is not what I would be worried about. How long have they been sitting, and why did this person pull upgraded struts after 10k? From what I have heard the Blistens are harder than the Tokicos and the quality is top notch, but there is something funny about this auction. These would have been mated with TRD (Eibach) springs originally, so lowering shouldn't be an issue, unless they are already bad struts.
TadS
Postby Paladin06Greg » Mon Nov 08, 2004 7:50 am
:o Keep in mind those struts require a special upper fitting which is not made anymore. I had those on my car long ago and a upper fitting failed and I could not get another.
I ended up changing all four to tokico which fit the OEM upper fitting
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Jai_Jai_Binks » Mon Nov 08, 2004 11:52 am
TadS wrote:TRD = Blisten on the Solara.
Migth i also add the discontinued blisten struts!
Postby ICrazyChrisI » Mon Nov 08, 2004 2:27 pm
Also to mention they prematurely blow
ICrazyChrisI
Postby krawzyazn » Mon Nov 08, 2004 3:23 pm
someone outbid me please lol my max bid is only $25
Postby greeensolara » Mon Nov 08, 2004 3:49 pm
krawzyazn wrote:someone outbid me please lol my max bid is only $25
hahahahah, suckaaaa!!!!!
greeensolara
Postby Paladin06Greg » Mon Nov 08, 2004 4:22 pm
:o Can you bail out??
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Mole » Mon Nov 08, 2004 8:46 pm
they look like they've been through some weather damage.
Postby MGLax13 » Mon Nov 08, 2004 8:50 pm
You can bail out, you can cancel the bid...just search on the e-bay website for how to cancel. When they ask for a reason, say someone used your name without permission, that always works.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby krawzyazn » Mon Nov 08, 2004 9:19 pm
salt from winter time in ny
Postby dimych » Mon Nov 08, 2004 11:49 pm
MGLax13 wrote:You can bail out, you can cancel the bid...just search on the e-bay website for how to cancel. When they ask for a reason, say someone used your name without permission, that always works.
i hope the guy that posted the auction doesn't read this board, because if he did that would backfire.
1999 Toyota Solara SE V6 Man.
Magnum SSB brake lines, eBay short ram intake, akibono ceramic brake pads.
dimych
Users browsing this forum: Google [Bot] and 42 guests
