SolaraGuy.com • View topic - TRD Cone air filtre on ebay, is this real?
Postby dimych » Mon Nov 08, 2004 10:06 am
Or is this another one of those eBay slap on a TRD sticker rip offs? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7932532640&category=33659
1999 Toyota Solara SE V6 Man.
Magnum SSB brake lines, eBay short ram intake, akibono ceramic brake pads.
dimych
Postby Paladin06Greg » Mon Nov 08, 2004 10:19 am
Sticker!!!! :x
Paladin06Greg
Torqued Solara
Torqued Solara
Postby dimych » Mon Nov 08, 2004 10:21 am
Paladin06Greg wrote:Sticker!!!! :x
that's a dissappointment, really wanted one, since K&N filtres are about $35-40.
dimych
Postby DatSRBoi » Mon Nov 08, 2004 8:21 pm
They should be ashame to fool people like that. What BS they are. Id hit them in the head. At least respect is all I have to say and dont cheat. Its fake stuff although it looks coolio in ways :-?
Postby Mole » Mon Nov 08, 2004 8:36 pm
K&N is just as good.
plus the "drop in" type filters retain better low end vs cone filters.
Postby Mandarinsolara » Mon Nov 08, 2004 9:43 pm
how about that HKS drop in filter for solara V6 im considering getting it so i can put an HKS sticker on the side of my car
Mandarinsolara
Postby DatSRBoi » Tue Nov 09, 2004 6:02 am
Little slow here..But how come cone only give us high ends? Also would just taking the WHOLE (the bottome filter holder and that small izzle pipe) bottom box out of the fatory intake give us both low and high? ahaha.
Postby sunrise_solara » Tue Nov 09, 2004 7:00 am
A certain amount of restriction is needed to maintain the pressure inside the intake, which in the case of the drop-in (k&n), provides low end power. The cone is so free-flowing that it makes none of the pressure, hence no low end power. However, the upside is that at the upper RPM range, the engine needs more air to make power, whereby now the free flowing cone can provide the needed air flow (and the drop-in, with the added restriction, begins to fade in air flow and power). At least that's how I understand it...
sunrise_solara
Postby Astro » Tue Nov 09, 2004 10:09 am
Mole wrote:K&N is just as good.
I wonder what the HP numbers are. When we took June's car for the Injen short-ram, we got the dyno from the K&N drop-in. I'm just curious what the '04 would dyno with the stock filter. We got around 10-14 HP with the short-ram, so would the drop-in give about 2-3 or 3-4 HP?
Postby DatSRBoi » Tue Nov 09, 2004 1:36 pm
sunrise_solara wrote:A certain amount of restriction is needed to maintain the pressure inside the intake, which in the case of the drop-in (k&n), provides low end power. The cone is so free-flowing that it makes none of the pressure, hence no low end power. However, the upside is that at the upper RPM range, the engine needs more air to make power, whereby now the free flowing cone can provide the needed air flow (and the drop-in, with the added restriction, begins to fade in air flow and power). At least that's how I understand it...
In that case someone needs to go invent a drop in multirev cone filter haha.
Postby Duffman » Tue Nov 09, 2004 1:47 pm
Mandarinsolara wrote:how about that HKS drop in filter for solara V6 im considering getting it so i can put an HKS sticker on the side of my car
The HKS filter will get you 4-5 HP; are you assuming the stickers will give you another 2 or 3? :drinking:
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Users browsing this forum: Google [Bot] and 42 guests
