SolaraGuy.com • View topic - Speedo & Tach Needles - Other Colors?
Postby Duffman » Tue Nov 09, 2004 8:22 am
I did a search and found nothing...
I've seen a couple people's cars on here (would go picture hunting but work blocks cardomain pages) that have their speedo and tach needles in colors other than red. How, and what did you do? I'm interested in changing mine. Is it just a bulb change?
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby Jon11582 » Tue Nov 09, 2004 9:21 am
It's lit by the backlight. As far as I know, only orange and red are possible, unless you do some modification to the needles, like soldering a LED and required resistors in. I never seen a solara with any other colors though. I wouldnt recommend pulling the needle off at all because of possible caibration issues, but for those that are confident enough, and have some wiring and electrical skills, it may be something worth trying.
2000 Black Solara SE
Jon11582
Postby Astro » Tue Nov 09, 2004 10:00 am
I haven't bought anything here, but they have some interesting stuff.
Silver Image Racing
Here is the needle kit they have.
Postby Fresco Bob » Tue Nov 09, 2004 5:39 pm
Fresco Bob
Postby Jon11582 » Tue Nov 09, 2004 8:00 pm
Thats kinda smooth, how he put a piece of plastic under the needle where it shines through. Might give that a shot when I'm bored sometime.
Also, for the link that astro showed, thats a UV neon near the gauges, with the needles with different colors of UV reactive paint on them.
What I was talking about was more something like this:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... otohosting
Jon11582
Postby RayCarlo » Wed Nov 10, 2004 4:37 am
I actually have done the needle color modification, mine are blue, it required removine the needles, taking the orange color off and repainting them blue, and then installing blue LEDs under the gauge faces, it seemed like it was easy when i started, but it was actually pretty hard to do, since the LEDs had to be ground down so that they would be flush against the gauge faces. anyway here's what i used
http://www.angelfire.com/fl5/import/indigloneedles.html
RayCarlo
Postby Jon11582 » Wed Nov 10, 2004 12:21 pm
Hey buddy U did that man? I'd like to see some pics if you can scrounge a few up.
Jon11582
Postby Hsakuragi » Wed Nov 10, 2004 12:37 pm
ya, if you don't know what u are doing, don't play with the needles.... :wink:
Hsakuragi
Postby swimshady906 » Thu Nov 11, 2004 12:42 am
Has anyone does LED's for the whole console?
02' S2000 Silverstone
swimshady906
Postby RayCarlo » Thu Nov 11, 2004 5:20 am
Jon, i'll try to take some pics so you can see it, one of the leds is not lit though so one of the needles won't be blue, one of the wires came loose from the resistors and i just have felt like taking out the whole thing and re connect it, kinda a hastle. Getting more and more lazy with age.
RayCarlo
Postby RayCarlo » Wed Nov 17, 2004 10:33 am
here's a really bad pic taken with my phone.
RayCarlo
Postby Jai_Jai_Binks » Wed Nov 17, 2004 12:07 pm
Jon11582 wrote:, unless you do some modification to the needles, like soldering a LED and required resistors in. .
There was a dude who took them off and put something else in its place...this is from really really old clublexus.com ES forums....(yeah, we ES's are plagued with dying needles and dealerships want close to 7 bills for a new cluster)....Looked tackey....but it was a mod!
Postby impactX » Thu Nov 18, 2004 4:36 pm
Mine.
I had to sand down the red color on the needle, repaint the back of the needle with white (like the Camry needle.) and I order a set of LED kit to put behind the gauges. In order to install that, you need to pull the needles.
Do not try to retrofit big LEDS into the gauge, it won't work. The gauge is pretty sofisicated in terms of how the light is distributed.
impactX
Users browsing this forum: Google [Bot] and 42 guests
