SolaraGuy.com • View topic - double sided tape
double sided tape
double sided tape
Postby Vi3tT3kNiqz » Sun Nov 14, 2004 7:57 pm
i'm redoing my TRD kit. What brand of double sided tape do you recommend me getting? And how strong should I get? when i search around, the strongest i could find is 5 lbs. Is there anything stronger? And where can i find it? Thankz guys.
Vi3tT3kNiqz
Postby thakidd » Sun Nov 14, 2004 7:58 pm
i used 3m got it at autozone.
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby trdkamuri51o » Sun Nov 14, 2004 8:06 pm
3m and get adhesive promotor.
trdkamuri51o
Postby ICrazyChrisI » Sun Nov 14, 2004 9:49 pm
Have fun taking the tape off the kit.
ICrazyChrisI
Postby Jaimster » Sun Nov 14, 2004 9:58 pm
Just re-tape along the old tape, not on top! If ya want to do it fast!.
Jaimster
Postby badjura » Sun Nov 14, 2004 10:28 pm
i guess you didn't add any additional tape the first go around?
badjura
Postby 2002greenhornet » Mon Nov 15, 2004 8:06 am
Jaimster wrote:Just re-tape along the old tape, not on top! If ya want to do it fast!.
You mean just below or just above the old tape line?
Steve
2002 SLE V6
2002greenhornet
Postby Jai_Jai_Binks » Mon Nov 15, 2004 9:00 am
When i redid my retaping, all i did was try to get the old one off best i could (i couldn't get 100% out), then i just used the 5lbs 3m tape over the old tape!
Postby Vi3tT3kNiqz » Mon Nov 15, 2004 11:27 am
so the 5lbs tape works good? Do i need industrial strength for stronger hold? I dont want to have to redo it every year.
Vi3tT3kNiqz
Postby Yanks0114 » Mon Nov 15, 2004 11:37 am
The 5lb stuff should be fine.
Postby Jai_Jai_Binks » Mon Nov 15, 2004 3:38 pm
Vi3tT3kNiqz wrote:so the 5lbs tape works good? Do i need industrial strength for stronger hold? I dont want to have to redo it every year.
I've had my camry kit since 1999, thus far this is what i've done -
1. original molly designs tape in 1999
2. 5lbs tape in 1999 (fronts and rears)
3. 5lbs tape in 2003 (rears only)
4. i need to redo my fronts for sure during xmas or whenever time permits..
All this is depending on how much you drive or how your roads are....you migh have to redo it every 2-3 years. It ain't too shabby of the process. KNOCK ON WOOD, the sides are still on original tape!
Postby indiglosolara » Mon Nov 15, 2004 3:53 pm
im redoing my driver side skirt this weekend. Mine has been coming off slowly..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby JoeB » Tue Nov 16, 2004 11:21 am
For those of you who put your own kits on, did you use 1 piece of double sided tape or 2? The dealer put mine on so I don't know how it was originally. This year, I had some damage repaired and the guy that put the piece back on thought there were 2 pieces there originally. Common sense tells me that you wouldn't normally put tape on tape because it wouldn't stick that well. Looking at it now, it looks like it is separating between the 2 pieces of tape as I would expect. What did you guys do? -JoeB
JoeB
Postby 2002greenhornet » Tue Nov 16, 2004 1:35 pm
Joe, the original TRD kits have one strip of tape. At least the 20023 kit I just put on my car did. I agree that tape on tape would be a bad idea.
Steve
2002 SLE V6
2002greenhornet
Postby Yanks0114 » Tue Nov 16, 2004 5:24 pm
2002greenhornet wrote:Joe, the original TRD kits have one strip of tape. At least the 20023 kit I just put on my car did. I agree that tape on tape would be a bad idea.
You are correct, it was one strip of tape
Users browsing this forum: Google [Bot] and 42 guests
