SolaraGuy.com • View topic - 99/2k/2001 to 2002/2003 front end conversion
would you do a front end conversion from 99 to 2k2/2k3?
Poll ended at Mon Nov 04, 2002 8:24 pm
yes i would
11
61%
no i wouldn't
7
39%
Total votes : 18
Postby eyedea » Fri Oct 25, 2002 8:24 pm
flipside909 wrote: If I had the money, I would convert my front end to the 2002-2003 version just to get the advantage of a dual headlight system.
Is this really possible? Someone mentioned that the TRD 99/2k pacecars had a front end conversion to match the 2k2/2k3 models. If you had the money, would you do a conversion?
eyedea
Postby NASTY » Fri Oct 25, 2002 9:12 pm
hellllll no!
'01 SLE V6
NASTY
Postby Gunman » Fri Oct 25, 2002 9:14 pm
why not, the front of the new body style have nice curves for em, instead of the flat going across, gives it more style i think
Gunman
Postby onefiend » Fri Oct 25, 2002 9:18 pm
I wouldnt change...I like my 01 bumper with the over sized fog lights, and I dont like that tear drop part on the new headlights...
The only thing I like about the 02-03 bumper is that its pointy. Other than that I like mine.
onefiend
Re: 99/2k/2001 to 2002/2003 front end conversion
Postby Flipside909 » Mon Oct 28, 2002 2:43 pm
It is really possible, that's why I mentioned it. I have a bias to dual headlamp systems over single bulb dual filament systems.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Kenn157 » Mon Oct 28, 2002 5:52 pm
If it were possible I would.
Had a 99 Solara SE V6. Had a 06 Tacoma. Now I have a 2008 Camry SE V6
Kenn157
Postby Blaze » Mon Oct 28, 2002 5:56 pm
too expensive i think? just try to make a custom light setup :) like a silvia conversion
Blaze
Postby Yanks0114 » Mon Oct 28, 2002 6:59 pm
I love our front end, but flip is right, the dual filament bulbs suck. Now that i am looking into real HID systems it so upsetting to see that i will lose hi beams because of the H4 bulb
Postby Gunman » Mon Oct 28, 2002 8:02 pm
so on the older models, you have one bulb? but if your gonna do the hid, what would you need the high beams for anyway?
Gunman
Postby Flipside909 » Mon Oct 28, 2002 10:15 pm
Gunman wrote:so on the older models, you have one bulb? but if your gonna do the hid, what would you need the high beams for anyway?
Well it's nice to have a seperate high beam to "flash" when you need to for safety purposes or signal purposes. I prefer a dual setup over a single. Illumination is much better with a dual, due to the reflector design.
www.clublexus.com
Flipside909
