SolaraGuy.com • View topic - More stopping power for solaras
Postby swimshady906 » Tue Dec 21, 2004 1:49 am
I just finished installing a 93+ supra TT master cylinder on my 2000. Since the supra is a 1" there is a 14% gain in surface area compaired to our 15/16" stock cylinder. This means more fluid is pushed through the lines, more pedal effort, less pedal movement. Now there is a slightly longer than stock pedal stroke with a firm, easily modulated feel. With ericsol's 13" rotor kit, SS brakelines and this mastercylinder ... the stopping power is amazing. My dealership sells mastercylinders for the supra (solara is the same price) for a little over $200... you can also pick up a remanufactured one from a local parts store for around $65. If you can bleed brakes, you can do this swap. :D
02' S2000 Silverstone
swimshady906
Postby Alex(AUS) » Tue Dec 21, 2004 5:42 am
Hi Swimshady,
Did you have to remove the break fluid reservior? I need to move mine (I have a RHD Aussie Camry and the reservoir is in the way of supercharger pulley :D ). If so, can you please explain how you did it?
Thank you,
Alex
Alex(AUS)
Postby TadS » Tue Dec 21, 2004 7:06 am
Sounds cool. Can you post up a DIY, or some pictures?
TadS
Postby eugene5786 » Tue Dec 21, 2004 9:06 am
can those big supra claipers fit on our rotors too?
eugene5786
Postby swimshady906 » Tue Dec 21, 2004 1:31 pm
Yes you have to remove the fluid reservior but only to put it on the new one. It is pretty much a stock replacement...
Ill do a diy today or tomorrow and ill put some pics up.
I dont think the supra calipers bolt on to our hubs, that would require some sort of bracket.
swimshady906
Postby wiz2 » Tue Dec 21, 2004 1:46 pm
Sounds good I cant wait to see the pics. :)
06 DG G35 Sedan 6 MT
motordybe spacer|stillen tube|MRR GT 1 19x8.5,19x9.5 Toyo T1R's
wiz2
Postby Mole » Tue Dec 21, 2004 3:00 pm
eugene5786 wrote:can those big supra claipers fit on our rotors too?
no. well with modification im sure
Re: More stopping power for solaras
Postby impactX » Tue Dec 21, 2004 8:50 pm
swimshady906 wrote:I just finished installing a 93+ supra TT master cylinder on my 2000. Since the supra is a 1" there is a 14% gain in surface area compaired to our 15/16" stock cylinder. This means more fluid is pushed through the lines, more pedal effort, less pedal movement. Now there is a slightly longer than stock pedal stroke with a firm, easily modulated feel. With ericsol's 13" rotor kit, SS brakelines and this mastercylinder ... the stopping power is amazing. My dealership sells mastercylinders for the supra (solara is the same price) for a little over $200... you can also pick up a remanufactured one from a local parts store for around $65. If you can bleed brakes, you can do this swap. :D
Did you install Ericsol's kit and the master cylinder together or did you install the cylinder after driving around with the big rotor kit for a period?
impactX
Postby swimshady906 » Wed Dec 22, 2004 4:51 am
impactX wrote:Did you install Ericsol's kit and the master cylinder together or did you install the cylinder after driving around with the big rotor kit for a period?
I drove around with the 13" kit for over a year and there is a noticeable difference :D
swimshady906
Postby Alex(AUS) » Wed Dec 22, 2004 6:03 am
Hi Swimshady,
Is it hard to remove the fluid reservoir? Do you mind posting the steps in this thread or your tutorial?
Thank you,
Alex
Alex(AUS)
Postby swimshady906 » Wed Dec 22, 2004 1:36 pm
To remove the acctuall reservoir you only have to remove one phillips screw, to take off the entire master cylinder there are two 12mm bolts and two brake lines. Ill put pics up later today.
swimshady906
Postby impactX » Fri Dec 24, 2004 8:04 pm
Wow I will give this a try when my master cylinder goes.
impactX
Postby cam2Xrunner » Sat Dec 25, 2004 8:08 pm
If any of you guys are interested one of the members from TN is making new brackets so you can now use the Supra TT calipers as well.
http://www.toyotanation.com/forum/t59427.html
cam2Xrunner
Postby impactX » Mon Dec 27, 2004 1:51 am
The only problem with that kit is that you can't go back to the 16" rims if you live in a place that sees snow.
impactX
