SolaraGuy.com • View topic - trouble installing rear center valence on trd kit
Postby hari-bhari » Mon Dec 27, 2004 1:03 pm
anyone have trouble doing this? i cant get those two screws/clips out. theyre really funky
hari-bhari
Postby Hsakuragi » Mon Dec 27, 2004 2:15 pm
use a flat screw driver, peel the center "nipple" out, then pull the whole screw out
Hsakuragi
Postby Mole » Mon Dec 27, 2004 6:13 pm
break it off. :lol:
at the top you should be able to squeeze it out by needle nose or if your fingers are small enough.
Postby hari-bhari » Mon Dec 27, 2004 9:57 pm
can i really break it off? cuz hey, if i can, then i will if i wont be needing it anyways
hari-bhari
Postby Mole » Tue Dec 28, 2004 2:55 pm
i think you need to re-use them.
not too sure.
Postby Hsakuragi » Tue Dec 28, 2004 5:01 pm
yes, u need them to hold it, unless u brought 2 new ones
Hsakuragi
Postby jazzlara » Mon Jan 17, 2005 6:47 pm
if its trd, the kit comes with two new ones. f the clips, i didnt use them, everythings is snug from bolts and 3m
jazzlara
