SolaraGuy.com • View topic - Which wiper blades should I get?
Postby SolaraGuy22 » Wed Dec 29, 2004 1:43 pm
I am in the market for new wiper blades and I didn't see many posts about them when I did a search. I pretty much narrowed it down to two companies. I would like your opinions. HELP!
http://www.piaa.com/WiperBlades/WiperBlades.html
or
http://www.boschusa.com/AutoParts/WiperBlades/
-Anthony
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby pythonjosh » Wed Dec 29, 2004 11:44 pm
I just use RainX.
pythonjosh
Postby Mole » Wed Dec 29, 2004 11:49 pm
dont need no lights on my wipers... (yeah i know they make wipers...)
i'd go with bosch. why? well simply i have them too.
but any new wiper will do.
Postby Hsakuragi » Thu Dec 30, 2004 2:15 am
just get Yota's..cheap
Hsakuragi
Postby Jon11582 » Thu Dec 30, 2004 8:47 am
Thier easy to replace, and thier pretty cheap. I think a new midgrade blade is going to perform better than a high-qual semi-used blade, so I just go to Walmart and get what they have. I think I got the tripleblade since they seemed quality, but were on the cheap side. (I think it was around 4 bucks per blade).
If they get worn down, just slap on another set. Can even keep a set in the trunk for a toolless 20-second roadside replacement if you realize your blades are getting worn.
I think my methodology is sound, but someone tell me if I'm wrong here and spell out why I should get a high-qual blade instead.
Just for the record, I use Mobil 1 in all my oil changes, and use good brake pads and tires, so I don't always cheap out on replacable parts, I just don't think theres a reason to go with high end wiper blades.
2000 Black Solara SE
Jon11582
Postby MalBandito99 » Thu Dec 30, 2004 9:05 am
I went with some $13 hoity-toity teflon blades from Autozone a month ago when I replaced my Boschs which has been on for a year, neglected by my having to replace them. They perform just as well as the Boschs. Its for how long they last is what you pay for, I think. I'll see as time goes with these ones.
MalBandito99
Postby TadS » Fri Dec 31, 2004 8:21 am
=TadS (from 2003 post) I use Triple Edge wiper blade inserts. I have had really good luck with them for the last 7 years or so. I bought a set for my Solara the day I got it, and they still haven't failed on me . I convinced one of my friends to spend the extra 10 bucks and try them on his Neon last week, as his were old blades had split. We have had major storms all week here, and yesterday he actually called me on his cell to tell me how good they were LOL.
Sill feel the same way another year later. Good blades.
TadS
Postby Fletch » Mon Jan 03, 2005 6:13 am
PIAA's are worth the extra money. My set has lasted at least 3 years and they are just now kind of wearing out. There is another high end brand, Valeo or something, they are on Tirerack's website.
2006 Legacy GT spec.B
Fletch
Users browsing this forum: No registered users and 104 guests
