SolaraGuy.com • View topic - spring install question....
Postby lazyboyz69 » Mon Jan 03, 2005 6:09 pm
i had the bg coilover they are kinda like the jic coilovers or the tien coilovers and i'm installing the tien/tokico setup cuz the bg coilovers got bent.... installin the tien/tokico do i need the stock upper rubber insluator, metal plate bracket, and the bearing?
lazyboyz69
Postby lazyboyz69 » Mon Jan 03, 2005 6:11 pm
or actually the spring upper seat when installin the tiens...i went to the shop to do this install but they didn't finish because they said i was missing some parts and its not safe driving it....
lazyboyz69
Postby Mole » Mon Jan 03, 2005 6:14 pm
huh?
unless the bg strut mount is able to be swaped then yeah, but if not, you need to buy a set of stock strut mounts.
Postby lazyboyz69 » Mon Jan 03, 2005 6:53 pm
the strut mounts are the same..... but is there anything that goes on top of the spring before teh strut mount..... or inbetween the spring and the strut mount..... the shop said they needed a rubber insulator, metal plate bearing and a bearing....
lazyboyz69
Postby Mole » Mon Jan 03, 2005 7:13 pm
hmmm
a dust boot... thats all i can think about.
like i said earlier, take a picture of the area since no one knows abotut he B&G system.
Users browsing this forum: No registered users and 97 guests
