SolaraGuy.com • View topic - knuckle...where is it?
Postby lazyboyz69 » Fri Jan 07, 2005 7:28 pm
well i hit a curb going pretty fast, the shop said i need to replace the knuckle....does anyone know where it is.... or the hub....
lazyboyz69
Postby krook » Tue Jan 11, 2005 1:36 pm
might be between the "finger chasis" check the index hub and the middle hub. there should be a joint from those extensions.
krook
